Webmail not working through ADSL router ?
27 Oct 2003
I have one of these from Overclockers -
Dynamode R-ADSL-C4WEG 54Mbps Wireless ADSL2+ Modem/Router/Switch/Firewall (NW-000-DN)
Basically any webmail ( Hotmail, Yahoo etc ) does not work through it. You get the login page, input user credentials and press login, the page refreshes and displays the login page once more.
If I change the router it works fine..!! Can someone please help me out.
I'm not aware of any ports I need to open to allow webmail, certainly on the other routers ( Netgear, Dlink ) that work no particular ports are open.
Thanks
tolien said:
On AOL by any chance?
No mate, it's freeserve. It's not the ISP as I have tried the router with both Freeserve and Zen ADSL providers with the same result. If I change the router voila webmail works fine.
C'mon guys any other suggestions ?
Might be worth disabling the firewall on the router to see if that helps. Could be something as simple as blocking cookies I guess....
i had this problem with my safecom. try playing around with the mtu size using drtcp. The default value is 1500 bytes but try settinng it to 1492.
If that doesnt work keep lowering it with these values 1478, 1458, 1430,
