Websense and NTL
19 Apr 2003
Ive stuck a site on my NTL space and used the forwarding thing from 123reg to direct people to it.
The other day I tried to access it from a company using Websense and it blocked it. Theres nothing bad in any way on it.
Any ideas why ?
edit/ Never mind I found the likely answer. Because its sharing a IP address with other NTL users if ones blocked they are all blocked. Theres a bit on the Websense site called 'SUGGEST A URL CHANGE' by all accounts they will unblock you quickly once they are aware of the problem.
TDF.
Ive heard back from websense, theyre going to take me off whatever undesirable list I was on and put me in Business and Economy.
Is there a way to check if any of the other filtering services have blocked my site ?
TDF.
