Website auto login?
18 Oct 2002
Is there any way to create a shortcut that automatically logs into a website that needs a username & password?
My Netgear router status page, for example, comes up with a box asking for username & password - can I bypass this with a command line type shortcut?
Thanks.
Not sure if it works on pop-up window logins. But opera comes with a feature called magic wand (i think thats what it's called). You type in your use name and password, for example on these forums. Then whenever you next need to log in, you press ctrl+enter and it logs you in automatically :)
