Website Help! :)
5 Aug 2004
North East England
Currently I really suck with CSS and making websites. I've made my usual layout with a header etc but there are a few minor glitches. I've tried changing the code to what I think it is but it won't work! :(
Here's the link :
www.sinque.org/test
There is a gap at the bottom of the header and to the right of it. The header is only 2px smaller than the box width ways but it looks a lot bigger.
The gap on the outsides of the news boxes(where it says 'Website Under Construction.'), to me, don't look equal. :rolleyes:
So I was just hoping that some CSS wizard could swoop down here and check out my code for errors etc. :)
Cheers in advance, Sinque.
I haven't chance to look at it properly at the moment but I see your site doesn't validate. Generally I make sure my site validates first before I try and fix my layout because otherwise you can't be sure whats causing the problem (ie bad html or bad css.)
Is this your site? I ask because the second line of the source code tells the world that's where the template originated, and at face value all you seem to have done is changed the header image and text... :confused:
There's your answer :p
Edit : Just tried to fix it then it all messed up so I gave up :rolleyes: Thanks anyway.
