Website help!
28 Sep 2004
Devon, UK
Hi currently making a website for the local youth centre! This is the first time that I have built a website from scratch! I used photoshop then the slice tool.
Something doesn't look right though! The colour can't really be changed because thats what has been used on the leaflets and flyers!
Any hints or tips would be appreciated!
I know there are some duff links as I haven't made those pages yet!
http://www.twobeds.com/upload/userfiles/MarkLP/
Thanks,
Mark
Probably the fact that the content doesn't stretch all the way to the bottom makes it look a little strange.
The comic sans is horrible too.
Can you tone down the splodge?
If you mean the blue in the middle of the page, then yes I can, seemed really bare with just white so I added that, brought it to life abit.
Could you suggest a modern, clear, but you know the funky, youth cluby :confused: :p font?
Cheers,
Mark
Look for a decent list of web safe fonts. Anything else isn't really going to work for the text.
Obviously you can use whatever fonts you like in images.
