I bought the missus’ engagement ring from Bluenile and was very happy with the price and quality. Now is the time we both need to start looking at wedding rings. Unfortunately, the range of wedding rings on Bluenile is not that great, certainly for her.
She needs 18k white gold so it’s the same as the ring, but just a bog standard band, no diamond encrusted lark. Around the 3-4mm thickness. Bluenile only does 2mm which is a bit too thin. I’m not entirely sure about want I want, but again just want something plain and simple.
Anyone got any suggestion on where to look? High street prices are pretty ludicrous. They’re about half the price I paid for her engagement ring, but that has a honking great diamond on top! Price is an important factor, <£500 for both rings ideally.
Also, if it’s just a plain 18k white gold band, can there be a difference in quality? Obviously there can be if you’ve got intricate details carved in or jewels on it, but for a bog standard band, surely 18k is 18k right? Or are there different qualities/quantities of coatings you can get?
Thanks for any advice.
