** WEEK INSANITY: MONITOR MADNESS, UK's LOWEST PRICES BY MILES!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
OcUK is destroying its competition, check our these awesome monitor deals:-
Acer Predator XG270HUomidpx 27" FREESYNC 144Hz Gaming Widescreen LED Monitor - Black/Red (UM.HG0EE.001) @ £299.99 inc VAT
The first FreeSync monitor available for pre-order, based on a very unique high performance TN panel designed for gaming with a 2560x1440 resolution, 144Hz, 1ms, Zeroframe and FreeSync support.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by AMD FREESYNC™ technology
Specification:-
- Screen Size: 27" (69cm)
- Resolution: 2560x1440 WQHD
- Panel: TN
- Response Time: 1ms
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1 (100,000,000:1 DCR)
- Connectivity: 1x DVI-D, 1x HDMI, 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- FreeSync Enabled
- Speakers: 2x2W Stereo
- Warranty: 2yr (Return to base with Acer - 0371 760 1000)
- Compatible with both NVIDIA & AMD Graphics Cards (FREESYNC Function only works with AMD cards)
Was [£349.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
BenQ XL2730Z 27" FREESYNC 144Hz Gaming Widescreen LED Monitor - Black/Red @ £399.95 inc VAT
**FREESYNC AMD Drivers are launched 19th March**
From years expertise in the development of professional gaming monitors and every close encounter with legendary gamers around the world, we have learned that what defines a truly victorious gaming monitor, or should you say “the best gaming monitor”, really depends on the performance-driven features that make the critical difference between victory and defeat. Gaming is in the details that matter. This is why our engineers and designers strive to perfect every detail that may ultimately contribute to the triumph of the game.
Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
BenQ’s new Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond count. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory.
It is absolutely vital that the XL2730Z give you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance setting to meet gamers’ specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your preference and to simulate any in-game experience. Using the Display Mode function, the monitor can be easily changed between 7different screen sizes, from 17”, 19”, 19”W, 21.5W”, 22”W, 23”W, 23.6”W, 24”W and 27”W.
If you’re looking to customize your screen size further, you can also take advantage of the Smart Scaling feature. The Smart Scaling feature gives you the flexibility to freely scale the screen content to any custom size. With just one monitor, you can simulate any game play and practice under different display sizes for tournaments. Use the Display Mode and Smart Scaling together to get the possible view for any application or game.
The newly improved Black eQualizer Dynamic color engine technology takes visibility optimization to a whole new level with automatic brightness adjustments. The XL2730Z is able to detect the input source and automatically fine-tune the amount of brightness enhancement within the range of the brightness level selected by the user. Now, gamers can spot their enemies in critical combat effortlessly and react to any situation quickly without having to lift a finger for manual adjustments.
To ensure that gamers can duplicate the exact same monitor set-up with the highest accuracy, efficiency and convenience, BenQ made a few additions to the XL2730Z’s Adjustment Scale Design. The adjustable height stand is now scaled with 14 height levels trackable by a moving marker. Trackable scales are also added to the screen, which tilts forward and backward to 0°, 10° and 20°, and swivels left and right to a wide range of angles. Every XL2730Z can be your personal XL2730Z.
The S Switch Arc is an external controller that comes with preset buttons that can be customized with personal display settings for gaming, work or entertainment use. The S Switch Arc not only sports a quick key for the Auto Game Mode but also a rounder look for a more natural and comfortable grip that enables gamers to best navigate between game modes.
The newly upgraded Display Pilot function allows users to make all the on-screen display adjustments, plus provides them with direct access to the Game Mode Loader feature for downloading and installing the preset display settings of their favorite game or professional gamer’s screen instantly.
The Auto Game Mode enables the XL2730Z to detect the genre of the game being played and switch the display setting to the corresponding game mode automatically. It is also designed to make new game mode recommendations for download. This unique feature is accessible through the On Screen Display (OSD) setting as well as the Display Pilot software or the S Switch Arc that has a quick key built in for this mode.
To save gamers the hassle of having to re-download and reset game modes, the XL2730Z allows gamers to store game modes onto a USB flash drive for easy and simple carriage. They can also share their own game modes with everyone via cloud storage or social media platforms. This innovative feature allows gaming communities to share, collaborate and bond freely with ease.
Sporting the latest angular, compact base that aligns perfectly parallel to the desk surface and a monitor stand meticulously placed in golden ratio to counter balance the display, the next-generation base stand design offers a new level of stability for the steadiest gameplay – with stringent swivel and shock testing results to prove it. Additionally, the reduced width and depth further shortens the distance between the keyboard and the monitor, bringing you closer than ever to the game.
The aluminum alloy coated monitor stand sends off a sophisticated yet mysterious metallic appeal that conjures up the majesty of the game. On top of that, it is ergonomically optimized with a widened and thickened top handle that’s comfortable to grip, making the monitor much easier to carry from one place to another.
Placing a retractable headphone hook on the left side of the monitor display conveniently puts your headphones within arm’s reach. The material of the headphone hook, which has been upgraded to aluminum alloy, offers extra hardness and strength for improved durability.
Practice long hours with clear, comfortable vision or compete with top-notch vision condition with BenQ’s new Low Blue Light. The blue spectrum light, which is produced by regular computer screens, is a critical cause of eye damage, eyestrain, headaches and sleeping disorders. Now with the offering of various adjustable low blue light levels, gamers can better protect their eyes. So there would be no need for yellow tinted eyeglasses for additional eye protection, and gameplay can be clear, comfortable and hassle-free!
Developed in collaboration with pro gamers, the XL2730Z has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Features:-
Specification:-
- Panel: TN
- Connectivity: 1x Dual Link DVI, 1x HDMI 2.0, 1x HDMI 1.4, 1x DisplayPort 1.20 (Display Cable and USB cables included)
- USB 3.0 Hub
- FreeSync Enabled
- Dimensions (HxWxD mm): 557.4x663.7x226.0
- Weight: 8kg
- Height adjust stand with pivot, swivel and tilt
- Full Specification: http://gaming.benq.com/gaming-monitor/xl2730z/specification/#skip
- Warranty: 2yr
Was [£429.95] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
Acer Predator XB240HA 24" G-Sync 144Hz Gaming Widescreen LED Monitor - Black/Red (UM.FB0EE.A01) @ £259.99 inc VAT
In competitive gaming, every frame matters. Introducing Acer's XB0 Series gaming monitor - the Full HD resolution monitor that can keep up with your game play. Through NVIDIA G-Sync technology, on-screen action is smooth and clear, minimizing distractions, boosting response times, and giving you a serious competitive edge. Plus, users can enjoy comfortable viewing experience while gaming via flicker-less, low dimming and ComfyView display. Its VESA compatible mounting offers a sleek, space saving option in tight spaces and power-saving technologies conserve cost and resources.
Acer XB0 24" monitor features Full HD resolution (1920 x 1080) presenting stunning, high quality images with excellent detail that not only enhances users' working efficiency, but creates outstanding visual enjoyment.
NVIDIA G-SYNC technology synchronizes the monitor's refresh rate to the GPU render rate providing the smoothest, fastest gaming experience. G-SYNC even eliminates screen tearing and minimizes display stutter and input lag when users start playing games so scenes appear instantly and sharper.
This monitor is 3D ready! Just purchase an NVIDIA 3D Vision 2 Wireless Glass Kit and NVIDIA 3D LIGHTBOOST technology and you can experience 3D gaming and enjoy home entertainment like never before!
Fast response time of 1ms GTG (Gray to Gray) enhanced gamers' in-game experience. No matter the fast-moving action or any dramatic transitions will be all rendered smoothly without the annoying effects of smearing or ghosting.
Acer's large 24-inch flicker-less monitor eliminates annoying screen flicker, and provides a comfortable viewing experience, especially for those heavy monitor users, like programmers, writers, students or graphic designers.
The ErgoStand pivots and tilts for the best viewing angle while the height can be adjusted for different desk heights with a simple push or lift.
Features:
- Acer XB0 24" monitor features Full HD resolution (1920 x 1080) presenting stunning, high quality images with excellent detail that not only enhances users' working efficiency, but creates outstanding visual enjoyment
- NVIDIA G-SYNC technology synchronizes the monitor's refresh rate to the GPU render rate providing the smoothest, fastest gaming experience.
- A fast response time of 1ms enhances the in-game experience. No matter how fast-moving the action is, transitions are rendered smoothly without the annoying effects of smearing or ghosting.
- Signal Inputs: 1 x Display Port
Specification:
Specification:-
- NVIDIA G-Sync Technology
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 100.000.000:1
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz (DVI Port)
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Height adjust, pivot & Swivel
- VESA: 100x100mm
- Warranty: 2yr
Only £259.99 inc VAT.
ORDER NOW
Asus PG278Q ROG Swift 27" G-Sync 144Hz Gaming Widescreen LED Slim Bezel Monitor - Black/Red @ £539.99 inc VAT
Quite possibly the best gaming monitor ever made and ideally suited to NVIDIA cards with 3D Vision 2.0 and G-Sync technology. This monitor runs at a staggering 2560x1440 resolution with 144Hz technology and a 1ms response, even better this is the latest in TN technology.
The ROG SWIFT PG278Q represents the pinnacle of gaming displays, seamlessly combining the latest technologies and design touches that gamers demand.
This 27-inch WQHD 2560 × 1440 gaming monitor packs in nearly every feature a gamer could ask for. An incredible 144Hz refresh rate and a rapid response time of 1ms eliminate lag and motion blur, while an exclusive Turbo key allows you to select refresh rates of 60Hz, 120Hz or 144Hz with just one press. The ROG SWIFT contains integrated NVIDIA® G-SYNC™ technology to synchronize the display's refresh rate to the GPU. This technology eliminates screen tearing, while minimizing display stutter and input lag to give you the smoothest, fastest and most breathtaking gaming visuals imaginable. Connectivity is simple, yet robust, with a single DisplayPort 1.2 port to enable NVIDIA® G-SYNC™ and dual USB 3.0 ports for convenience.
Conventional 60Hz monitors show extensive motion blur which detracts from your gaming experience. The ROG SWIFT PG278Q Gaming Monitor with NVIDIA® Ultra Low Motion Blur technology* reduces the effects of motion blur by delivering crisp edges in fast-paced gaming environments for perceivable differences in natural movement.
ASUS-exclusive GamePlus Technology enhances your gaming experience further by providing you with crosshair overlays for FPS games and multiple in-game timers for RTS/MOBA games.
The ROG Swift has a super-narrow 6mm bezel that begs this monitor to be used in multi-display gaming set-ups. With VESA wall mount capability and an ergonomic stand designed with full tilt, swivel, pivot and height adjustments, the ROG SWIFT is ready for long gaming sessions in comfort.
The ROG SWIFT PG278Q represents the next generation in gaming displays. This WQHD 2560 x 1440 monitor delivers four times the resolution of 720p, with 109 pixels per inch or 109 RGB matrices per inch. This gives you the benefits of greater image detail and up to 77% more onscreen desktop space than standard Full HD (1920 x 1080) displays. These minor details add up to give you a major in-game advantage.
Unlock the highest frame rates available, decimate lag and say goodbye to motion blur to gain the upper hand in first person shooters, racers, real-time strategy and sports titles. With twice the frame rate of standard LCDs, the ROG SWIFT PG278Q Gaming Monitor encourages you to never blink again.
Response time and ultra-smooth gameplay are the hallmarks of a true gaming monitor. With a 1ms rapid response time – the fastest available – the ROG SWIFT PG278Q Gaming Monitor eliminates smearing, tearing and motion blur, allowing you to quickly react to your game.
NVIDIA®G-SYNC™ display technology delivers the smoothest, fastest and most breathtaking gaming imaginable. G-SYNC™ synchronizes the ROG SWIFT's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. Scenes appear instantly, while objects look sharper and more vibrant. Gameplay is fluid and responsive too, ensuring a serious competitive edge.
The ASUS Display R&D team works closely with NVIDIA to ensure that everything runs smoothly on ASUS G-SYNC™ monitors. The ROG SWIFT PG278Q gaming monitor with built-in G-SYNC™ delivers super smooth and stunning visuals.
The ROG SWIFT PG278Q is compatible with the NVIDIA® 3D Vision™ 1 and 2 kits* to support up to three WQHD displays for immersive multi-display 3D gaming experience. ROG SWIFT provides the finest 3D gaming and content viewing experience and thanks to the ever-growing library of over 700 3D Vision™ ready game titles, as well as 3D Blu-ray movies and YouTube 3D Playback support. See everything in a new dimension with the ROG SWIFT.
*Requires NVIDIA® 3D Vision™ kit, sold separately.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by NVIDIA®G-SYNC™ technology
- Exclusive GamePlus onscreen timer/crosshair, 60-120-144Hz refresh rate turbo key and intuitive 5-way OSD navigation joystick
- Complete ergonomic tilt, swivel, pivot and height adjustment with VESA mount capability for optimal placement
Specification:-
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (68.47cm)
- Pixel Pitch: 0.233mm
- 2D mode: 2560x1440 (up to 144Hz)
- 3D mode: 2560x1440 (up to 120Hz)
- 2D Surround: 7680x1440 (up to 144Hz)
- 3D Surround: 7680x1440 (up to 120Hz)
- Panel: TN
- Colour: 16.7M (Real 8-Bit)
- Connectivity: 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- 3D Vision 2.0 Enabled
- G-Sync Enabled
- ULMB Enabled (NVIDIA Ultra Low Motion Blur Technology)
- Phys. Dimension with Stand(WxHxD): 619.77x362.96x237.9mm
- Box Dimension (WxHxD): 756x456x300mm
- Weight 7.5kg
- Full Specification: http://www.asus.com/Monitors/ROG_SWIFT_PG278Q/
- Warranty: 3yr (On-Site with Asus - 01442 265 548)
- OcUK Exclusive Service: Warranty regarding dead pixels falls under ISO rules and as such dead pixels if very few are not an actual fault. But at OcUK we value our customers especially when spending such a large amount of money on what is a flagship gaming monitor. As such even if you only have 1 dead/stuck pixel and it has not gone after 3 days, we will class the monitor as faulty and exchange it for you at no cost to you. This service is exclusive at OcUK for Asus ROG Swift ONLY or other qualifying monitors! (Valid for 28 days from purchase)!
Was [£549.95] Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
Acer Predator XB270HU 27" G-Sync IPS 144Hz Gaming Widescreen LED Monitor - Black/Red (UM.HB0EE.009) @ £539.99 inc VAT
The Acer XB270HU not only has a IPS panel, but it can do 144Hz IPS and has G-sync support as well, is this monitor nirvana.
What makes this very interesting is that it is labelled as an IPS screen, and offers support for 144Hz refresh rate and support for NVIDIA's G-sync refresh rate technology. This is the first display featuring an IPS panel with native 144Hz refresh rate.
Offering tilt, height and swivel stand adjustments. We believe the screen to feature only a DisplayPort video connection as reported before.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 4ms response time, made smooth by NVIDIA®G-SYNC™ technology
Specification:-
- Panel: IPS
- Response Time: 4ms
- USB 3.0 Hub
- G-Sync Enabled
Was [£589.99] Inc. VAT
ORDER NOW
Iiyama Prolite B2783QSU-B1 27" FREESYNC Gaming Widescreen LED Monitor - Black @ £259.99 inc VAT
The ProLite B2783QSU is an excellent 27” QHD LED-backlit monitor bringing the world of Business and Gaming together. The monitor offers accurate and consistent colour reproduction with wide viewing angles and a sharp high resolution 2560x1440 panel. Its ergonomic stand offers 13cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. This monitor supports FreeSync™ technology, offering gamers the chance to experience fluid and fracture free gaming. Triple input (DVI/HDMI/DisplayPort) and a USB HUB ensure compatibility with your desktop PC or Notebook.
Specification:-
- Panel: TN
- Refresh Rate: 60Hz
- Horizontal sync 30 - 90 KHz
- Vertical sync 50 - 75 Hz
- Contrast ratio: 1000:1 (120,000,000:1 DCR)
- Connectivity: 1x Dual Link DVI, 1x HDMI 1.4, 1x DisplayPort
- USB 3.0 Hub
- FreeSync Enabled
- Dimensions: w x h x d 622.5 x 400.5 (530.5) x 230 mm
- Weight: 6.1 kg
- Warranty: 3yr
Was [£269.99] Inc. VAT
ORDER NOW
AOC Q3277PQU 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £349.99 inc VAT
Experience a new level of sharpness with this large 32" monitor. The Q3277PQU utilises a state-of-the-art AMVA panel with the stunning QHD resolution of 2560 x 1440 pixels. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, plus speakers as well as a USB 3.0 hub integrated into the bezel, this display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. Benefit further from full ergonomic flexibility with 180 mm height adjustment, tilt, swivel and pivot (= portrait mode rotation) function. The Q3277PQU comes in a classy design and features eco-friendly LED-backlights.
Raise or lower the screen to suit each individual’s height and seating preferences. The easy-to-adjust stand ensures hours of viewing or working comfort.
Three-Year Warranty AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge.
With 2560 x 1440 resolution, Quad HD (QHD) offers superior picture quality and sharp imagery that reveals the finest details. The widescreen 16:9 aspect ratio provides plenty of space to spread out and work, plus allows you to enjoy games or movies in their original size.
Specification:-
- Screen Size: 32"W, AMVA LED
- Resolution (max.): 2560 x 1440
- 100% sRGB
- Height adjust, pivot & swivel stand
- Pixel Pitch: 0.276 mm
- Brightness: 300 cd/m2
- Contrast Ratio: 3000:1
- DCR: 80M:1
- Response Time: 4 ms GTG
- Display Color: 1.07 billion
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: D-sub / DVI-D / HDMI / DisplayPort
- Flicker FREE technology
- VA (AMVA+) LED Technology
- HDCP Support
- Speaker: 3W x2
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 3yr
Was [£359.99] Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
AOC U3477PQU 34" WideScreen Super-Wide LED Monitor @ £499.99 inc VAT
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
The 3440X1440 UltraWide QHD display offers amazingly sharp picture quality. Its pixel area is about 1.8 times larger than an UltraWide Full HD 21:9 monitor, and about 2.4 times larger than a Full HD 16:9 monitor. It provides an efficient environment in using Microsoft Office programs showing 47 columns and 63 rows in excel.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Multitasking doesn't have to mean shuffling back and forth between windows*. With a single click, the 4-Screen Split feature divides the screen into as many as four customizable segments, two-by-two. Now you can see four different windows at the same time.
The Dual Linkup feature allows two compatible portable devices--such as a computer, camera, phone, or Blu-ray player--to be connected to the monitor, and both can be viewed on the same screen simultaneously.
The DisplayPort digital video interface is used to connect a high-performance video source to a high-resolution monitor. Thanks to its sophisticated design, a DisplayPort cable can also be used to carry audio, USB signals and other data as well.
AOC’s LED backlighting delivers exceptional brightness and amazing image clarity. You'll see richer colors and deeper blacks too, and LEDs offer greater energy efficiency compared to conventional LCD monitors.
IPS (In-Plane Switching) technology enhances thA dynamic contrast ratio of 5,000,000:1 is your assurance of strong video performance, with deep blacks, bright whites and pleasing colors.e performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Response: 5ms
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort, 1x DVI-D, 1x Analogue
- Speakers: 2x 3W Stereo
- USB 3.0 Hub
- Height adjustment: 130mm
- Pivot & Swivel function
- VESA: 100x100mm
- Dimensions: Product with stand (WxHxD): 828 x 624.5 x 229.2 mm
- Warranty: 3yr (On-Site with AOC - 0808 234 3510)
Was [£539.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
BenQ BL3200PT 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £359.99 inc VAT
Accurate Color Gamut that brings your imagination to life, A Large Screen that extends your design space, High Resolution to view the smallest details, Ergonomic Features that ease your eye and neck strain... Result, A monitor that meets all your CAD/CAM needs!
With a 2560x1440 WQHD resolution and extra working space mean less scrolls for zooming in and out. Start using BenQ CAD/CAM Monitor now and boost your work efficiency!
The unique CAD/CAM Mode is specially designed to enhance work efficiency and reducing eye fatigue for all CAD/CAM users. By making the color contrast higher, every displayed line will be perfectly distinguished. With BenQ CAD/ CAM Monitors, you will never miss a line again in your designed work.
To clearly distinguish detailed textures in the darkest areas, BenQ developed Animation Mode that enhances brightness in dark areas without overexposing bright areas. With ten levels of brightness, the Animation Mode provides the comfort and freedom that every designer will welcome with open arms.
With the BenQ’s advanced 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience.
Auto Pivot detects the rotation of the monitor and dynamically rotates displayed content automatically. All windows will be equally portioned and displayed on the screen when clicking on the Desktop Partition icon, which allows you to compare all design works with just, one simple click. Moreover, you can preset different picture modes to each frequently used software. Display Pilot will automatically switch to your preferred picture mode in different user scenarios.
Unique control device docked to the stand of every BL3200PT monitor remotely accesses the OSD menu. Three pre-set hot-keys allow quick switching between 1. sRGB Mode, 2. CAD/CAM Mode, 3. Low Blue Light Mode, or let you assign your own set of display modes providing ultimate user flexibility.
Large screen monitors usually take a noticeable amount of space on the working desk. BL 3200 is designed to save as much of your workspace as possible. Compact stand architecture enables the screen to sit at the very edge of the desk and maximize your working space and comfort.
I/O ports on the side of the screen effortlessly bring all your content together in one convenient package. 2x USB 3.0 and SD card reader provide super-speed data transmissions.
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
An extensive range of monitor adjustments – height, tilt, pivot, stroke and swivel – tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150mm distance between the screen bottom and the base.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but they can certainly feel them. Free your eyes from flickers by switch to CAD/ CAM Monitors and let your eyes do less work while you are working on CAD/ CAM designs.
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light Modes from OSD hot key (Multimedia – 30% reduction, Web-surfing – 50% reduction, Office – 60% reduction, Reading – 70% reduction), and reward your eyes without having to lose the visual enjoyment. Corporate users are frequently required to read documents from a monitor. Reading Mode adjusts the screen brightness, contrast ratio and sharpness to make your eyes feel as easy as reading directly from hard copies without wasting any paper.
Specification:-
- Screen Size: 32"W, VA LED
- DCR: 20M:1
- Senseye® Human Vision Technology (plus Senseye 3)
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- Dimensions(HxWxD mm) HIGH: 640.16*740.28*232.48mm
- Warranty: 2yr (On-Site with BenQ - 0207 216 0039)
Was [£389.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
BenQ BL3201PT 32" 4k 60Hz Professional Widescreen LED Monitor - Black @ £599.99 inc VAT
The BL3201PT, a stunning 32”W display built with IPS technology and the latest 4K2K ultra-high-definition resolution, as a part of its continued effort to support the visual-intensive work required in the fields of CAD/CAM, animation, video editing and graphics arts. So professionals with a meticulous eye for detail can work with perfect precision and achieve high productivity.
Designed to meet the rising demands for large-sized viewing and ultra-high definition, the BL3201PT boasts a 32”W 4K2K display built with BenQ’s advanced IPS technology, providing professionals in CAD/CAM, animation, video editing and graphic arts ultra-precise color rendition and over 300% working space to enhance their work efficiency and productivity.
Every color is delivered with the finest precision in every detail and at every possible viewing angle for a great viewing experience. With a 10-bit panel that renders more than one billion hues, every image is displayed with the richest, liveliest colors.
Professional CAD/CAM engineers and designers work with extremely detailed information, making superb display clarity and color accuracy absolutely vital for ensuring design precision. BenQ’s BL Series offers a number of display solutions for maximized display performance, including the CAD/CAM Mode to bring out even the smallest details to view for Pro/E, SolidWorks, AutoCad, CATIA or other CAD/CAM software. Recognizing the multi-tasking and collaborative nature of the work, thoughtful features that support a wide range of viewing options are included to ensure high productivity can be preserved while users run a number of tasks simultaneously or compare and discuss design work with colleagues.
For clearly distinguished details in complicated object wireframes, switch on the CAD/CAM Mode to alter the monitor’s color and contrast settings to view highly detailed graphic information without ever missing a line again.
SolidWorks Certification Being a Solidworks Solution partner translates to display excellence certified to be of professional standard for CAD/CAM software users.
Professional animators work to breath life into moving art, making even the tiniest detail paramount to delivering lively creations. To answer the visual demands of the most sophisticated animators, BenQ BL Series monitors give you uncompromising accuracy consistency for displaying every shade of colors through a wide range of optimized image calibration settings, including the brightness-enhancing Animation Mode. There is also a multitude of viewing features incorporated into the monitors to simultaneously display all the information needed for making color adjustments. So no detail can escape the eyes of its creator!
To make distinguishing detailed textures in darkened areas easier, BenQ developed the Animation Mode to enhance the brightness in dark areas of the artwork – without overexposing bright areas. This allows animators to fine-tune their animation creation effortlessly.
Color accuracy and a clear line of view are of utmost importance for anyone working in the field of professional video editing. BenQ BL Series offers a wonderful range of 100% sRGB monitor with a resolution of QHD and 4K2K UHD to give you crisp and clear viewing quality accompanied by true, lifelike colors. The large viewing space combined with optimal viewing prevision give video editors full access to all the editing tools, applications and images they need to work with. So they can perform every task with maximized efficiency.
A high-quality monitor with high resolution, high color accuracy and fidelity and a wide range of high-speed connectivity options is what makes a perfect companion for professionals in the graphic arts industry, including graphic designers, retouchers and photographers. Featuring the highest resolution at 3840x2160 4K2K with 100% sRGB and BenQ’s advanced IPS technology, the BL Series showcases consistent, reliable color results with every detail precisely rendered for a brilliant viewing experience from virtually every perspective. A variety of connectivity and view options also enables users to work with multiple devices and perform complex multi-tasking work with ease.
Designed for professional designers accustomed to work with a square monitor, this feature allows them to work with nearly two 19” displays by dividing a 32” BL Series monitor screen into two 4:3 or 5:4 viewing areas – which can be further resized from 19”S to 30”W in size using the Display Mode feature. For enhanced convenience and productivity, the PIP/PBP feature allows you to compare two or more pictures as well as display drawings from two PCs simultaneously for a more efficient work discussion.
The Display Pilot software is a total solution package for designers seeking to customize their display. You can assign specific color modes to frequently used software applications on your computer with Application Tuning, and Display Pilot software will automatically apply the preset color mode to the matching software application in use. Other features that can also be accessed through Display Pilot include Auto Pivot, Desktop Partition, PIP/PBP and other OSD settings such as brightness adjustments.
Auto Pivot detects the movement of the monitor and dynamically rotates the contents displayed for flexible landscape or vertical viewing without utilizing Windows or graphic card settings. The BL Series are newly upgraded with the incorporation of BenQ’s proprietary Flicker-free Technology to eliminate backlight flickering at all brightness levels and effectively reduce eye fatigue. Conventional LCD screens flickers 200 times per second. The flickers may not be detectable by your eyes but they can certainly feel the flickering. So it is important to relieve your eyes from the stress caused by a flickering screen – and keep them nice and fresh when you are working on new designs.
Features:-
- 32”W Large Screen 3840x2160 UHD Resolution
- 100% sRGB Color Space
- Display Pilot Software
- OSD Remote Access
- CAD/CAM Mode and Animation Mode for Precision Design
Specification:
- Display Screen Size: 32"
- Aspect ratio: 16:9
- Panel Type: IPS
- Brightness: 350cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 20,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 4ms (GTG)
- Color Support : 1B
- Viewing Angle (H / V ): 178 ° / 178 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz), 1x Mini-DisplayPort (60Hz), 1x DVI-DL
- USB Hub: Yes (USB3.0)
- Speakers: Yes (2x 5W Stereo)
- VESA: 100x100mm
- Height adjust, pivot, swivel stand
Was [£659.99] Inc. VAT
Only £599.99 inc VAT.
ORDER NOW
Philips BDM4065UC 40" 4K 60Hz Widescreen LED Monitor - Black @ £559.99 inc VAT
See the big picture with all the details. The expansive 40" class Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in Ultra HD. Expand your viewing experience with the monitor that is designed for the way you work.
These latest Philips screens deliver UltraClear, 4K UHD (3840x2160) pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like DisplayPort, HDMI, Dual link DVI, these new displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets. Philips displays will give you UltraClear images.
Philips VA LED display uses an advanced vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, movies, gaming, and demanding graphical applications. It's optimized pixel management technology gives you 176/176 degree extra wide viewing angle, resulting in crisp images.
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturati on and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
Mobile High Definition Link (MHL) is a mobile audio/video interface fo r directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
Features:
- Expansive 40-inch class brilliant display
- UltraClear 4K UHD (3840x2160) resolution for precision
- VA display gives awesome images with wide viewing angle
- MultiView enables active dual connect and view at same time
- SmartImage presets for easy optimized image settings
- LED Technology ensures low power and natural colors
- Slim bezel design for a stylish look
- Powerful 7-Watt speakers to unleash your content
- USB 3.0 Hub for convenient access and fast charging
- SmartConnect with DisplayPort, HDMI and VGA connections
- MHL technology for enjoying mobile content on big screen
- VESA mount allows for the perfect setup
Specification:
- Display Screen Size: 40"
- Panel Type: VA
- Brightness: 300cd/m2
- Contrast Ratio: 5000:1 (Typ)
- Dynamic Contrast Ratio: 500,000,000
- Response Time: 3ms (GTG)
- Viewing Angle (H / V ): 176 ° / 176 °
- USB 3.0 Hub: Yes
- Speakers: Yes (2x 7W Stereo)
- VESA: 200x200mm
- Warranty: 2yr (On-Site with Philips)
Was [£575.99] Inc. VAT
Only £559.99 inc VAT.
ORDER NOW
Acer 4k2k B286HK 28" Professional Widescreen LED Monitor - Black (UM.PB6EE.009) @ £281.99 inc VAT
Ideal for use in office environments, libraries and computer labs, B6 Series monitors deliver dynamic and energizing visuals thanks to their high display resolution and true-to-life colors. They also feature an ergonomic design for comfortable all-day computing, and they use eco-friendly technologies to save power and cut energy costs.
Specification:
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 28" (71cm)
- Panel Type: TN
- Colours: 16.7m
- Dynamic Contrast Ratio: 100,000,000
- Response Time: 1ms (GTG)
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort, 1x Mini-DP, 1x DVI and 1x HDMI
- USB 3.0 Hub
- VESA: 100x100mm
- Speakers: Yes
- Warranty: 2yr (On-Site with Acer - 0371 760 1000)
Was [£289.99] Inc. VAT
Only £281.99 inc VAT.
ORDER NOW
AOC Q2577PWQ 25" QHD IPS Professional Widescreen LED Monitor - Silver/Black @ £221.99 inc VAT
This monitor with QHD resolution ensures that users can enjoy a full view of a document, spreadsheet, or website at a single glance without the need of scrolling. IPS technology is one of the highest performing panel technologies currently available for displays. This way, AOC makes sure users will greatly benefit from high accuracy in colour, contrast and wide viewing angles. In order to give users a variety of options for connecting different input sources, the AOC Q2577PWQ comes with DisplayPort, HDMI, DVI and VGA. Also comes with AOC's Flicker Free technology that ensures a zero-flickering viewing experience.
Features:
- Enjoy 63.44 cm (25") of superb screen clarity on a sharp QHD 2560 x 1440 resolution monitor. Plus, you get great colour consistency across an ultra-wide 178°/178° viewing angle.
- Get exceptional colour accuracy and consistency right out of the box, with each monitor factory tuned at 99% sRGB with a delta
- Easy Arrange lets you choose how you view your custom window layout. See all your applications tiled side by side with nothing buried
- Smoothly pivot 90° clockwise or counter-clockwise, placing the thinnest edges side-by-side for an enhanced viewing experience, especially ideal for dual or multi-monitor set up
- The Q2577PWQ is VESA-compatible, so you can wall mount your monitor or attach it to the optional Dell Single Monitor Arm
Specification:
- LED Backlit
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 25" IPS Widescreen
- Contrast Ratio: 80,000,000:1
- Brightness: 350cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 178°/178°
- Colours: 16.7 Million
- Inputs: 1x HDMI, 1x DisplayPort, 1x DVI-D, 1x Analogue
- VESA Compliant
- Warranty: 3 Years On-Site
Was [£229.99] Inc. VAT
Only £221.99 inc VAT.
ORDER NOW
AOC Q2770PQU 27" Widescreen LED Monitor - Black @ £275.99 inc VAT
Experience a new level of sharpness with this large 68.6 cm (27”) monitor. The q2770Pqu utilises a state-of-the-art Super PLS panel with the stunning WQHD resolution of 2560 x 1440 pixels. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, plus speakers as well as a USB hub integrated into the bezel, this energy-efficient display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. Benefit further from full ergonomic flexibility with 130 mm height adjustment, tilt, swivel and pivot (= portrait mode rotation) function. The q2770Pqu comes in a classy black texturised design and features eco-friendly LED-backlights .It fulfils sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold. Let the q2770Pqu impress you today!
Specification:-
- Monitor Size: 27"
- Visible Screen Size: 68,6 cm
- Brightness: 300 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1 (DCR)
- Contrast Ratio Typical: 1.000:1
- Pixel / Dot / Pitch: 0.311 (H) x 0.311 (V) mm
- Display Area: 597.89 (H) x 336.31 (V) mm
- Viewing Angle: 178°/178° (CR=10)
- Response Time: 5 ms GtG
- Maximum Resolution: 2560x1440@60Hz
- Recommend Resolution: 2560x1440@60Hz
- Colors: 16.7 M
- Connectivity: 1x VGA, 1x DVI-D, 1x Display Port Input, 1x HDMI
- Dimensions (WxHxD): 642 x 558 (+130) x 245
- Weight: 7.5 kg
- Warranty: 3 Years (On-Site with AOC - 0808 234 3510)
Was [£329.99] Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Asus VN279H 27" Widescreen Super Slim Bezel Multimedia LED Monitor - Black @ £161.99 inc VAT
The ASUS VN series features compact dimensions- this 27” display has a super narrow bezel of just 0.8cm, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN279H is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution.
VN279H leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and rich connectivity including dual HDMI/MHL and D-sub inputs. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey. VN279H adopts 178°(H) / 178°(V) ultra wide viewing angle AMVA+ panel that eliminates color shift on your screen no matter where and how you look at it.
With 100,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the VN279H enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life. ASUS includes its exclusive QuickFit Virtual Scale feature with the VN279H , allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
VN279H comes with rich connectivity including dual HDMI/ MHL and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
Features:
- Ideal for a multi-screen solution with a super narrow frame
- Best for work and play with Full HD 1080p visual quality and 178° ultra wide viewing angle AMVA+ panel
- ASUS VividPixel Technology for crystal-clear and detail-oriented enjoyment
- MHL (Mobile High-Definition Link) function for Enhanced Viewing from Mobile to Monitor
Specification:
- Panel Size(diagonal): 27"(68.6cm) Wide Screen (16:9)
- Display Viewing Area(HxV): 597.6 x 336.15mm
- Panel Backlight/ Type: WLED/ AMVA+
- Display Surface(non-glare/ glare): non-glare
- Color Saturation: 72%(NTSC)
- True Resolution: 1920x1080
- Pixel Pitch: 0.311mm
- Brightness (Max.): 300cd/m
- Contrast Ratio (Max.): 3000:1
- ASUS Smart Contrast Ratio(ASCR): 100,000,000:1
- Viewing Angle (CR?10): 178°(H)/178°(V)
- Display Colors: 16.7M (real 8 bit)
- Response Time: 5ms(GTG)
- Flicker-free: Yes
- Trace Free Technology: Yes
- SPLENDID™ Video Intelligence Tech. (Mode): 6 modes
- Skin-Tone Selection: 3 modes
- Color Temperature Selection: 4 modes
- HDCP: Yes
- QuickFit (modes): 4 modes (A4/ Letter/ Alignment Grid/ Photo)
- GamePlus: Yes (crosshair / Timer)
- Vivid Pixel Technology: Yes
- Stereo Speaker: 2W x 2 stereo, RMS
- Signal Input: HDMI/MHLx2, D-Sub
- PC Audio Input: Yes (3.5mm Mini-jack)
- AV Audio Input: HDMI
- Earphone Jack: 3.5mm Mini-jack( for HDMI/MHL)
- Analog Signal Frequency: 31.5 ~ 67.5 KHz(H) / 56 ~ 75 Hz (V)
- Digital Signal Frequency: 31.5 ~ 67.5 KHz(H) / 56 ~ 75 Hz (V)
- Power Saving Mode: <0.5W
- Power Off Mode: <0.3W
- Voltage: 100-240V, 50 / 60 Hz
- Chassis Colors: Black
- Tilt(angle): +22° ~ -5°
- VESA Wall Mounting(mm): 100 x 100mm
- Kensington lock: Yes
- Phys. Dimension with Stand(WxHxD): 619.2 x 440.4 x 209.8mm
- (For VESA Wall Mount): 619.2 x 362.4 x 48.3mm
- Box Dimension (WxHxD): 706 x 536 x 188mm
- Net Weight (Esti.): 4.8kg
- Gross Weight (Esti.): 7.5kg
- Warranty: 3yr
Was [£179.99] Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
Samsung SyncMaster S27D390H 27" Widescreen Slim Bezel LED Monitor - Black @ £149.99 inc VAT
Samsung’s newest Touch of Colour design is sure to command attention. Upholding Samsung’s ToC design legacy, the SD390 was crafted to catch the light of its surroundings in various beautiful ways, but brings a narrow bezel, slim and sleek black body and transparent neck to create a sophisticated and tasteful look that’s finished off perfectly with a subtle hint of soft pure blue along the bezel – making this unique monitor illuminate light and stand out in a way you’ve never seen before.
On or off, the stylish SD390 is sure to stand out wherever it is. Its narrow bezel design lets you see more of the screen while illuminating a subtle hint of soft pure blue that sets an elegant glow around the monitor. Its transparent crystal neck gently gleams in the light with a beautiful touch of blue and raises the screen to the perfect viewing level. The tilt feature increases your field of vision and maximises your viewing comfort. The SD390 will no doubt fulfill your every design desire.
Get perfect viewing for games with just one touch of a button. Game Mode adjusts your monitor’s settings instantly to give you an optimised gaming experience. Game Mode smartly detects the changes in scenes, enhances the colour and alters the screen’s contrast to make dark spots darker and light spots lighter so you can see all the action at all times. There is less lag thanks to a faster video response time that ensures that the picture keeps up with action and won’t let you down.
Get the best view from any angle with the SD390. Unlike conventional monitors, your Samsung LED Monitor has an extra-wide viewing angle of 178 degrees, vertically and horizontally. This means great picture quality from even more perspectives – whether you’re sitting down low and playing games or if several people are sitting around the monitor to watch a video. Whatever the situation, you can enjoy great viewing.
Magic Upscale improves image quality to such a level that you will only receive a better picture. Enjoy enhanced image quality no matter what the original picture quality is. Magic Upscale prevents image degradation when scaling up and gives only brilliant and pristine colours and images. And it also makes images on the monitor appear clearer and sharper than on a notebook. Shine with the SD390.
The Samsung SD390 monitor gives you all the connections you need to make the most of all your entertainment and other content. HDMI compatibility gives you access to games consoles, Blu-ray players and other AV devices, while a D-Sub connection mean you can plug in most PCs. You can easily connect your devices and use the monitor for working, gaming, viewing content and more.
Specification:-
- Screen Size: 27
- Aspect Ratio: 16:9
- Panel Type: PLS
- BLU Type: LED
- Brightness (Typical): 300cd/m²
- Peak Luminance Ratio: 99%
- Dynamic Contrast Ratio: Mega
- Resolution: 1920 x 1080
- Response Time: 5ms (GTG)
- Viewing Angle (H/V): 178° / 178°
- Color Support: 16.7M
- Connectivity: 1x Analogue & 1x HDMI
- Full Spec: http://www.samsung.com/uk/consumer/pc-peripherals/monitors/essential/LS27D390HS/XU
- Warranty: 2yr (On-Site with Samsung - 0330 726 7864)
Was [£169.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Samsung S27D850D 27" Widescreen LED Professional/Gaming Slim Bezel Monitor - Black @ £299.99 inc VAT
Samsungs latest flagship monitor ideal for gamers, professionals and photography experts.
Specification:-
- Screen Size: 27"
- Panel Type: PLS
- Backlight: LED
- Contrast Ratio: 10,000,000:1
- Pixel Pitch (HxV): 0.2331mmx0.2331mm
- Viewing Angles: 178/178
- Colour Support: 1.07b
- Connectivity: Dual Link DVI, DisplayPort, HDMI, USB Hub
- Speakers: No
- Stand Type: Height Adjustable (130mm), Tilt, Swivel & Pivot
- VESA: 100x100
- Set Dimension with Stand (WxHxD): MAX: 627.4 x 596.3 x 280 / MIN: 627.4x 466.3 x 280mm
- Set Dimension without Stand (WxHxD): 627.4 x 376.4 x 66.1mm
- Warranty: 3yr (On-Site with Samsung - 0330 726 7864)
ORDER NOW
Acer Predator GN246HLBBID 24" 144Hz 1ms Gaming Widescreen Monitor @ £199.99 inc VAT
The Acer Predator GN246HL brings spectacular 3D action to your digital content, dramatically enhancing the experience of everything from Full HD Blu-ray movies, immersive games, family photos, 3D CAD applications and even 3D medical analysis.
The Predator GN246HL is the first 24" LED monitor to support NVIDIA 3D LIGHTBOOST technology, combined with a powerful 144Hz frequency for added depth, image clarity and high-definition emotion to your desktop experience.
Specification:-
- Monitor Size: 24"
- Contrast Ratio Dynamic: 100,000,000:1
- Viewing Angle: 176°/170° (CR 10)
- Refresh rate: 144Hz
- NVIDIA 3D Vision Ready
- Colors: 16.7M
- Inputs: Analogue, DVI-D, HDMI
- Dimensions with stand(WxHxD): 565 x 400 x 178 mm
- Dimensions without stand WxHxD): 565 x 342 x 23 mm
- VESA: Yes (100x100)
Was [£239.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Iiyama ProLite GE2488HS-B1 24" 1ms Widescreen LED Super Slim Bezel Monitor - Black @ £119.99 inc VAT
ProLite GE2488HS is a real game changer, giving true hardcore gamers the competitive edge they need to make split second decisions. It features a response time of 1ms, which ensures fluid and accurate transition between the images and effects ghosting or smearing issues directly. Additionally, it is also possible to adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas. The ProLite GB2488HSU is an ideal screen for the strategy games (like RTS, MOBA and MMO) and the demanding gamers who settle only for the best specifications.
Specification:-
- Diagonal: 24"
- Panel: TN LED
- Display area: h x w 298.89 x 531.36 mm; 11.8" x 20.9"
- Response time: 1 ms
- Contrast: 1000 : 1 typical
- Contrast: 12000000:1 ACR
- Brightness: 250 cd/m² typical
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v 0.277 x 0.277 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: DVI/DP: 30 - 80 KHz
- Vertical sync: DVI/DP: 55 - 75 Hz
- Synchronization: Separate Sync
- Digital input connector: DVI-D, HDMI, Analogue
- HDCP: yes
- Headphone connector: Yes
- Output connector: headphone socket
- Speakers: 2 x 1 W (Stereo)
- Anti-theft-device Kensington-lock™ prepared
- Certificates: CE, TÜV-Bauart, GOST-R, VCCI-B, PSE
- Tilt angle: 20° up; 2° down
- VESA mounting: 100 x 100 mm
- Weight: 5.5 kg
- Warranty: 3yr (On-Site with Iiyama - 01926 819 189)
Was [£129.95] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Samsung SyncMaster S24D390HL 24" Widescreen Slim Bezel LED Monitor - Black @ £139.99 inc VAT
Magic Upscale improves image quality to such a level that you will only receive a better picture. Enjoy enhanced image quality no matter what the original picture quality is. Magic Upscale prevents image degradation when scaling up and gives only brilliant and pristine colours and images. And it also makes images on the monitor appear clearer and sharper than on a notebook. Shine with the SD360.
Specification:-
- Screen Size: 23.6"
- Panel Type: PLS
- BLU Type: LED
- Brightness (Typical): 250cd/m²
- Warranty: 2yr
Was [£149.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
Asus VS228DE 22" Widescreen LED Monitor - Black @ £79.99 inc VAT
VS228DE Full HD LED monitor, with 50,000,000:1 high contrast ratio, is optimized for the finest image and colour quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Key Features:-
- True-to-life Pictures Powered by LED
- Full HD 1080p Support
- Versatile viewing positions with Smart View Technology
- Aspect Control function
- Splendid Video Intelligence Technology
Specifications:-
- Screen Size: 21.5"
- Screen Type: LCD
- Backlight: LED
- Screen Features: Full HD
- Pixel Pitch: 0.248mm
- Horizontal Frequency Range: 30kHz - 80kHz
- Vertical Frequency Range: 55Hz - 75Hz
- Contrast Ratio: 600:1
- Dynamic Contrast Ratio: 50,000,000:1
- Brightness: 200 cd/m²
- Max. Resolution: 1920 x 1080
- Horizontal Viewing Angle: 90°
- Vertical Viewing Angle: 65°
- Tilt Angle: -5°/20°
- VGA Port(s): 1
- Product Width: 556mm
- Product Height: 443mm
- Product Length: 130mm
- Input Power Source: Power Lead
- Normal Power Consumption: 21.1W
- Stand-by Power Consumption: 0.5W
- Wall Mount: VESA 100mm x 100mm
Was [£85.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Great deals on monitors and on some of the above we are nearly upto £100 cheaper than competitors!
LIKE A BOSS!!
VIEW OUR ENTIRE MONITOR RANGE!!
