Weekend deal on Asus wireless Router
22 Apr 2014
As a special offer this weekend we are offering the Dual Band Asus Wireless N750 Router for a price of £79.99 and you also still get the free USB Wireless Adaptor as well.
Asus RT-N65U Black Diamond Dual-Band Wireless-N750 Gigabit Router (With free USB WiFi Dongle) @ £79.99 inc VAT
SuperSpeed USB 3.0 Data Sharing and Connections
The ASUS RT-N65U features the unique black diamond design and top performance of the award-winning RT-N56U, delivering exhilarating networking experiences. It comes equipped with a dual SoC architecture, one dedicated to 2.4GHz and the other to 5GHz, effectively offering the best concurrent throughput with up to a combined 750Mbps - great for high demand applications. Twin SuperSpeed USB 3.0 ports enhance file sharing and connectivity to devices, FTP, SAMBA, UPnP AV servers, and DLNA configurations. Equipped with powerful hardware NAT acceleration and built-in Gigabit Ethernet, the RT-N65U gives you full Gigabit internet performance, with its WAN and LAN throughput at over 900Mbps. In all, the RT-N65U's blend of design and performance guarantees truly great networking.
Whether you’re a tech-savvy enthusiast or a first-time user, the RT-N65U is exceptionally easy to use with CD-free Quick Installation Setup (QIS) that lets you plug-n-surf right out of the box and connect PCs, smartphones, tablets, and other wireless devices quickly. Thanks to its refined interface tools, you get control like never before, letting you monitor signal strength, setup parental controls, and access various useful functions in the most intuitive way.
Dual processors feature one dedicated to 2.4GHz and another to 5GHz, offering the best concurrent throughput with dual-band 2.4GHz and 5GHz operation at up to a combined 750Mbps. The 2.4GHz band can handle basic tasks like web browsing, while 5GHz performs more bandwidth-intensive tasks like HD video streaming and online gaming.
Featuring SuperSpeed USB 3.0 connectivity to devices, FTP, SAMBA, UPnP AV servers, and DLNA, the RT-N65U enhances data sharing and connections. Download HTTP, FTP, and P2P files to a router-connected USB storage device all day even without a PC. Additionally, the twin USB 3.0 ports allow networked printer and file server connections, so you can perform multiple tasks at once.
ASUS AiRadar intelligently strengthens connections to wireless devices. With high-powered amplification and beam packaging, it provides optimized signals in any direction with better coverage to improve your data throughput.
Equipped with a powerful hardware NAT acceleration engine and built-in Gigabit Ethernet, the RT-N65U gives you full Gigabit performance, making its WAN to LAN throughput up to 2-5 times that of traditional software-based NAT Gigabit routers.
With the RT-N65U, setup is a breeze. Simply power and connect the router and open a browser on a Wi-Fi-enabled device like a notebook or pad. You will then be taken to a setup page with a prompt to enter the ID/password from your internet provider, and that’s it! Setting up your network is easier than ever.
Support for a massive data pipeline of up to 300,000 data sessions means the RT-N65U has around 20 times the networking capacity of other high session routers, so multiple data transfer jobs don't slow down even during heavy load.
Download Master and DLNA server compatibility let you download and play multimedia files stored on router-attached USB storage on DLNA-enabled devices such as PC, pad, PS3, Xbox, and smart TV. Download Master can also download files while your PC is turned off, and allows you to manage and monitor download status remotely.
Do you game a lot, or spend most of your time streaming videos? Whatever your planned use is, the RT-N65U has Quality of Service (QoS) standards that let you select how much bandwidth is prioritized for virtually any task. Plus, the traffic monitor allows you to check your web usage in a clear graphical interface.
Was £109.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
