WEEKEND DEAL: ROUND 3 - MOTHERBOARDS
11 Dec 2005
Cheshire
Got yet more sweet weekend deals for you. Everything from X58, P67 and P55. Grab yourself a bargain as prices will go back up on Monday the 31st!
Asus Rampage II Extreme Intel X58 (Socket 1366) DDR3 Motherboard @ £169.98 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in. In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers. This motherboard supports the latest Intel® Bloomfield processors in LGA1366 package which has memory controller integrated to support 3-channel (6 DIMMs) DDR3 memory. Support Intel(R) QuickPath Interconnect (QPI) with system bus up to 6.4GT/s and a max bandwidth of up to 25.6GB/s. Intel® Bloomfield processor is one of the most powerful and energy efficient CPU in the world. The Intel® X58 Express Chipset is the latest chipset designed to support latest Intel® Core™ i7 Processors and Intel’s next generation system interconnect interface, Intel® QuickPath Interconnect (QPI), providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. It also supports up to 36 PCI Express 2.0 lanes providing better graphics performance. SLI or CrossFireX? Fret no longer because with the ROG Rampage II Extreme, you’ll be able to run both multi-GPU setups. The board features SLI/CrossFire on Demand technology, supporting up to three graphics cards in a 3-Way SLI or CrossFireX configuration. Whichever path you take, you can be assured of jaw-dropping graphics at a level previously unseen. The motherboard supports DDR3 memory that features data transfer rates of 1800(O.C.)/1600(O.C.)/1333/1066 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The triple-channel DDR3 architecture triple the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 43.2 GB/s.
- X58 Chipset
- Support for 6 Core Gulftown Extreme CPUs
- SLI and Crossfire Support
- 16 Phase Power
- Form Factor ATX
- Warranty: 3 Years
Was £179.99 Inc. VAT
Only £169.98 inc VAT.
ORDER NOW
Asus X58 Sabertooth TUF Intel X58 (Socket 1366) DDR3 Motherboard @ £144.98 inc VAT
Covering all the Essentials of Reliability
The key emphasis for TUF Series motherboards lies in enabling prolonged use. The SABERTOOTH X58 can keep going round the clock with no pause thanks to its meticulous thermal design, which means heat and stress are not obstacles. This new thermal design revolves around CeraM!X Heatsink Coating Technology, using revolutionary ceramic application on vital motherboard surfaces and components to ensure unrivalled heat resistance and dissipation. Thus, it is the perfect choice for server functionality and extreme, steady reliability. CeraM!X application has never been done on a motherboard before the ASUS TUF Series entered service.
Reliability Tested to Military Grade
The SABERTOOTH X58 from ASUS uses heavy duty materials and parts to ensure truly unmatched capabilities in terms of stability, reliability, endurance, and value.
The chokes, solid state capacitors and MOSFETs have all been tested under the most arduous of conditions and harsh environments based on military standards, providing users with a proven heavy duty solution.
TUF Series motherboards are ruggedized from the ground up, so they can handle more than just long-haul usage and heat. They are also tested to server-grade standards and can stand up to humidity and ambient temperatures to an exponentially larger extent than normal motherboards. As a consequence, they are long-life products users can install with complete confidence.
Being strong does not mean TUF Series motherboards compromise added features. The SABERTOOTH X58 ships with new data transfer standards USB 3.0 and SATA 6GB/s, so it offers some of the latest innovations in addition to superior strength. It is a complete package of guaranteed reliability and compatibility.
- X58 Chipset
- 8 Phase Power
- USB 3.0 and SATA 6GB/s
- Form Factor ATX
- Warranty: 5 Years
Was £157.99 Inc. VAT
Only £144.98 inc VAT.
ORDER NOW
Gigabyte P67A-UD3P Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) @ £119.99 inc VAT
Get ready for a mind blowing media experience when you upgrade to a GIGABYTE P67A-UD3P motherboard. Every component on GIGABYTE P67A-UD3P motherboards is designed and engineered to deliver exceptional performance and clarity for your computing needs. Powered by the Intel® P67 chipset with support for 2nd Generation Intel® Core™ processors, GIGABYTE P67A-UD3P enjoy uniquely developed technologies such as Maximum Power Delivery technology, Dual CPU Power technology and Ultra Durable 3™ design just to name a few, that ensure a reliable and enjoyable computing experience.
Like the pistons and cylinders of a car engine, the design of the motherboard Voltage Regulator Module (VRM), component quality and number of power phases greatly affects motherboard performance. GIGABYTE engineers were first to realize not only the importance of using the best quality components for this critical area, but also that with more power phases, there can be more power available to your CPU. GIGABYTE 6 series motherboards with their new redesigned VRM, promise to deliver first class system performance and power stability. With only the best quality components and unique design, incorporating Dual CPU Power and Power Phase Boost with Multi-gear Switching, your CPU can enjoy better power than what was available from previous motherboards.
GIGABYTE's cutting edge 12 phase power VRM design utilizes the highest caliber components to provide unadulterated, smooth power to the CPU. The innovative 12 phase power VRM has been designed and engineered to deliver fast transient response times through quick and seamless power delivery during extensive CPU loading variations. In addition, heat from the VRM is effectively reduced by spreading the load between the 12 power phases, resulting in a cooler, more stable platform.
Imagine a workstation class redundant (duplicated) power design on a desktop motherboard. GIGABYTE's proprietary Dual CPU Power Technology allows CPU VRM power phases to split evenly into 2 sets of power engines that operate in tandem. This allows 1 set of power phases to rest while the other is active, as opposed to a traditional power design, where all the power phases are always active. As such GIGABYTE Dual CPU Power effectively halves the amount of work done by each set of power phases to significantly increase motherboard durability and reliability.
GIGABYTE 6 series motherboards incorporate an Intel® approved Intersil PWM controller that is VRD 12 (Voltage Regulator Down) compliant. This means that it offers new features that include SerialVID (SVID) which transfers power management information between the processor and voltage regulator controller, allowing more robust and efficient signaling control between the CPU and PWM controller – hence, delivering a more energy efficient platform.
A traditional Voltage Regulator Module (VRM) consists of a Choke, Capacitors, MOSFETs and a Driver IC. By incorporating the MOSFETs and driver IC in accordance with the Intel® Driver-MOSFET specification, we can achieve higher power transfer and increased efficiency at higher switching frequencies to satisfy the growing power requirements of today's processors. Driver-MOSFETs also help to reduce VRM real estate requirements in the CPU zone.
GIGABYTE DualBIOS™ is a patented technology that automatically recovers BIOS data when the main BIOS has crashed or failed. Featuring 2 physical BIOS ROMs integrated onboard, GIGABYTE DualBIOS™ allows quick and seamless recovery from BIOS damage or failure due to viruses or improper BIOS updating. In addition, GIGABYTE DualBIOS™ now supports booting from 3TB+ (terabytes) hard drives without the need for partitioning, and enables more data storage on a single hard drive.
- Support for Intel Core i3/i5/i7 Socket 1155 Unlocked CPUs
- Support for 1333/1600/1866/2133MHz Memory
- 12 Phase Power
- Crossfire Support
- ATX Form Factor
- 3 Year Warranty
Was £129.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard @ £99.98 inc VAT
This motherboard supports the latest Intel Lynnfield and Clarkdale processors, which have the memory and PCI Express controller integrated to support 2-channel (4 DIMMs) DDR3 memory and 16 PCI Express 2.0 lanes, enabling higher graphics performance. Supporting the next-generation Serial ATA (SATA) storage interface with onboard Marvell controller, this motherboard delivers up to 6.0Gbps data transfer rates. Experience ultra-fast data transfers at 5Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10 times faster and is also backward compatible with USB 2.0 devices. Turn on IO Level UP to boost the USB 3.0 or SATA 6Gb/s data transfer rate to up to 500MB/s. Users can flexibly switch between full-speed PCIe x16 mode for their graphics cards and IO Level UP for rapid data throughput.
- Intel P55 Socket 1156 Core i3/i5/i7 support
- Crossfire Support
- ATX Form Factor
- 3 Year Warranty
Was £109.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
You may have just changed my mind about Sandy Bridge... Sabertooth at £145! Serious thinking is in order!
As a famous saying goes: "A wise man changes his mind, a fool never."
Not sure if I've just made this one up: "Consider all options before any one offer"
LOL - funny how different people read things different ways. I came from the idea he was going to upgrade to Sandybridge but with a cheap Sabertooth he may stick with the old stuff.
