- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Antec P280 Super Midi Tower Case - Gun Metal Black @ £79.99 inc VAT
The Antec P280 epitomizes cooling, quiet and sophistication. The durable polycarbonate layer prefitted deadens any noise and ensures Quiet Computing™. The P280 also boasts an new all black interior for a new updated feel from the older P180. . Additional features include two internal 2.5" SSD bays, and a mountain of 3.5" bays, excellent cable management and a special gunmetal gray finish for one-of-a-kind style.
- Supports up to XL-ATX Motherboards
- 9 Expansions Slots
- Quad GPU Support
- 6 Cable Routing Holes
- Bottom PSU mount with dedicated air filter
- Maximum Size CPU cutout
- Suipports GPUs up to 330mm long
- Top Power/Reset Buttons
- Front I/O Ports: 2 x Audio / 2 x USB3.0 / 2 x USB2.0
- 3 x 5.25" Drive Bays
- 2 x 2.5" Drive Bays
- 6 x 2.5" Drive Bays
- Top Cooling: 2 x 120mm TwoCool Fans
- Rear Cooling: 1 x 120mm TwoCool Fans
- Front Cooling: 4 x 120mm Fans (optional)
- Removable filters on PSU intake and front intakes
Only £79.99 inc VAT.
ORDER NOW
Antec P193 Super Midi Tower - Gun Metal Black @ £99.95 inc VAT
Larger and more versatile, the Antec P193 stands apart from the competition with room to handle the biggest hardware out there. Together with Quiet Computing™ technologies like silicone grommets and sound-deadening side panels, as well as cooling features like its dual chamber design and up to seven variable-speed fans, the P193 is in a class all its own. With its larger design, the P193 can handle everything from Extended ATX motherboards to multiple graphics cards to liquid cooling and more. The P193 Performance One enclosure offers the best of everything, size and versatility alongside Quiet Computing™ and exceptional cooling.
- Dual chamber design isolates heat and noise:
- External 4 x 5.25"; 1 x 3.5"
- Internal 6 x 3.5" for HDD
- Cooling system: 1 rear (standard) 120mm x 25mm exhaust TriCool™ fan , 2 top (standard) 140mm x 25mm exhaust TriCool™ fan, 1 lower front chamber (optional) 120mm fan for HDD, 1 side (standard) 200mm fan for dual graphics cards, 1 upper front (optional) 120mm fan for HDD, 1 middle (optional) 120mm fan for graphic cards
- Cable organizers behind motherboard tray minimize cable clutter
- Front I/O Ports: 2 x USB 2.0, 1 x eSATA, Audio In and Out (HDA and AC-97 compatible)
- Double hinged door opens up to 270°
- 7 expansion slots
- 0.8mm cold rolled steel chassis for durability
- Motherboard: Mini-ITX, microATX, Standard ATX and Extended ATX
- Case dimensions: 20.25" (H) x 8.1" (W) x 23.25" (D)
- Actual clearance needed for width is 9.5" due to the side panel fan: 51.4 cm (H) x 20.5 cm (W) x 59 cm (D)
Only £99.95 inc VAT.
ORDER NOW
Antec One Gaming Case - Black @ £36.98 inc VAT
For new builders and seasonal system integrators alike, everyone will find something to like in Antec’s One. This enclosure is stocked with features any builder will value at an attractive price – ample cooling, USB 3.0, tool-less 5.25” & 3.5” drive bays and bottom-mounted PSU intake with air filter – so that you can put your PC together with ease and get to the fun stuff. If you’re looking for high quality PC essentials at an affordable cost, then this enclosure is the One for you.
- 10 drive bays: 3 x 5.25” / 5 x 3.5” / 2 x 2.5”
- Motherboards: Standard ATX, microATX, Mini-ITX
- Maximum graphics card length: 10.5” (266 mm)
- Maximum CPU cooler height: 6.1”(155 mm)
- Top Cooling: 1 x 120 mm top exhaust fan
- Rear Cooling: 1 x 120 mm rear exhaust fan
- Side Cooling: 1 x 120 mm side intake fan (optional)
- Front Cooling: 1 x 120 mm front intake fan (optional)
- Bottom Cooling: 1 x 120 mm / 140 mm bottom fan (optional)
- 7 expansion slots
- Maximum-sized CPU cutout
- Water cooling support: rear water cooling grommets (support ½-inch tubes)
- Bottom-mounted power supply with intake filter
- No power supply included
- Front I/O ports: 2 x USB 3.0 with included USB 2.0 adapter / Audio In/Out
-Unit Dimensions: 438 mm (H) x 208 mm (W) x 488 mm (D)
Only £36.98 inc VAT.
ORDER NOW
Antec Sonata IV Quiet Case - Black (620W PSU) @ £89.99 inc VAT
Antec presents the Sonata IV, built from the ground up for Quiet Computing™ to continue the legacy of its predecessors. All of the features in the Sonata IV optimize the case’s quiet design, from the included 620 watt power supply with whisper-quiet 120 mm fan, to the redesigned case airflow that allows for maximum cooling with minimal fans, to the vibration-reducing silicone grommets for hard drives. Sonata IV is also the most capable Sonata to date, offering a 2.5” drive mount and front-panel USB 3.0. Created to give you a quiet, functional solution for your home, home office or corporate workspace, Sonata IV delivers.
- Power Supply: 620watt ATX 12V v2.3 with APF (80 Plus)
- Dimensions: 440 mm (H) x 208 mm (W) x 478 mm (D)
- Compatible Motherboards: Mini-ITX, microATX, Standard ATX
- Built-in washable air filters
- 4 x 3.5" Drive Bays
- 1 x 2.5" Drive Bay
- Expansion Slots: 7
- Cooling: 1 x rear 120mm Tri-Cool (3 speed switch) exhuast fan
- Front I/O Ports: 1 x USB3.0 2 x USB2.0 & 2 x Audio
Only £89.99 inc VAT.
ORDER NOW
- Quad GPU Support
ORDER NOW
- 7 expansion slots
ORDER NOW
- 7 expansion slots
ORDER NOW
ORDER NOW
