- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Intel Liquid Cooling Solution CPU Cooler (Socket LGA1155/1156//1366/2011) @ £66.98 inc VAT
Intel teamed up with no other than Asetek to offer the Intel RTS2011LC self contained water cooler kit. Asetek have been making these type of kits for a while and was behind the Corsair H50 and H70 as well as the Antec Kuhler 620 and 920.
- Socket LGA1155/LGA1156//LGA1366/LGA2011
- Fan Speed: 800-2200 RPM (4 wire PWM)
- Fan Dimensions: 120 mm x 120 mm x 25 mm
- Fan Airflow: 74CFM
- Unit Noise Level: 21dBA@800 RPM / 35dBA @ 2200 RPM
- Radiator Dimensions: 150mm x 118mm x 37mm
- Pump Z-Height: 33mm
- Total Thermal Solution Weight: 820 grams
- Cooling Liquid: Propylene Glycol
- Thermal Interface Material: TC-1996
Was £72.99 Inc. VAT
Only £66.98 inc VAT.
ORDER NOW
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) (CWCH100) @ £83.99 inc VAT
Featuring a full 240mm radiator and two performance matched 120mm fans, the Corsair Hydro Series H100 extreme performance liquid CPU cooler is designed to deliver cooling performance that meets the needs of even the most demanding performance enthusiast.
The H100 fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*. (*Requires the Corsair Link Commander, sold separately). The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool blue LED display lets you know at a glance which profile is being used.
- Dual length 240mm radiator for increased surface area and cooling potential.
- Corsair Link™ Digital compatibility means that you can be in complete control of your cooling.
- Push-button fan control so you can select the fan speed and cooling performance that best suits your needs.
- Two all-new 120mm fans optimize static pressure and airflow for amazing performance.
- FEP tubing provides extraordinarily low coolant evaporation levels.
- A new improved micro-channel cold-plate design more efficiently transfers heat.
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiation Dimensions: 120mm x 275mm x 27mm
- Fan Dimensions: 120mm x 25mm
- Air Flow per Fan: 46 - 92 CFM
- Combined Fans Noise Level: 25 - 42 dBA
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3 @ £38.99 inc VAT
nonl2brVenom Voodoo, this cooler is definitely rock and roll. Venom Voodoo delivers ultra high performance enabling serious system overclocking. The 12cm killer Viper yellow fan uses S-Flow blades providing 30% more airflow than a standard fan at the same speed. PWM function ensures quiet operation during normal system use and performance cooling under load.<br>
<br>
The Black cover and copper heatpipes combined with the Viper yellow elements creates a striking combination which adds pazazz to any system. Six high capacity heatpipes with direct CPU contact provide rapid heat transfer from CPU to high grade aluminium profiled fins. Anti-vibration rubber fan mounting pins provide easy installation and help to eliminate a lot of fan noise. Adjustable mountings ensure full compatibility with all current AMD and Intel CPU’s.<br>
<br>
Dual 12cm viper fans giving extreme performance in a push-pull setup where the first fan “pushes” air through the heatsink’s cooling fins, at the same time the second one “pulls” air through from the other side. The combined airflow of two 12cm fans results in more efficient heat dissipation and consequently lower CPU temperatures.<br>
<br>
- Dual 120mm PWM fans in killer viper yellow<br>
- Six high capacity 6mm heatpipes with direct CPU contact<br>
- Award winning S-FLOW fan blades provide 30% more airflow<br>
- Rubber fan mounts for easy install and quiet performance<br>
- Fan Dimensions: 120 x 120 x 25mm<br>
- Fan Speed: 600 - 1200 RPM<br>
- Max Airflow: 83.63 CFM<br>
- Noise Level: 6.9 - 28.9dBA<br>
- Cooler dimensions: 131 (W) x 129.5 (D) x 163.5 (H) mm <br>
<br>
<center><iframe width="560" height="315" src="http://www.youtube.com/embed/Rq3OJ5Jss_w" frameborder="0" allowfullscreen></iframe>
Was £44.99 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £20.99 inc VAT
nonl2brExcessive heat is the deadly enemy of high-performance silicon, and the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away. You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.<br>
The superior engineering of the Air Series A50 makes it dramatically outperform your CPU’s stock heatsink: three 8mm copper heatpipes directly contact your CPU and instantly pull heat up into the aluminum cooling fins. A 120mm fan, mounted on rubber studs to reduce noise and vibration, quietly draws cool air through the fins.<br>
Spend 15 minutes replacing your CPU’s stock heatsink and enjoy years of better performance.<br><br>
- Compatible with Intel and AMD systems<br>
- Three 8mm copper direct-contact heatpipes<br>
- Aluminum fins<br>
- Low-noise, low-vibration 120mm fan mounted on rubber studs<br>
- Selectable 1,600 or 2,000RPM fan allows you to select the cooling performance you want<br>
- Air flow: 50 - 61 CFM<br>
- Noise level: 26 - 31.5 dBA<br>
- Two-year warranty<br>
Was £26.99 Inc. VAT
Only £20.99 inc VAT.
ORDER NOW
Prolimatech Panther CPU Cooler (Socket LGA1155/1156/AM2/AM2+/AM3) @ £32.99 inc VAT
Prolimatech has taken its inspiration for this new cooler from the Armageddon, which results in the same excellent performance at a brand new price point. Both feature the same heatpipe shape, with the only difference being the number of such element as the Panther offers four 6 mm pipes.
In terms of construction, the cooler makes no compromises and offers the same level of quality as one has come to expect from Prolimatech. High quality Nickel plating has been applied to the entire cooler which does not only protect the unit but also results in a great look and feel. On top of that, the crossed fins increase the robustness of the Panther cooler.
The sophistication of this construction also shows in the shape of the heatpipes. These end in a row next to each other, so that each of them has unrestricted access to the fresh airflow of the included fan. This maximizes the efficiency of the Panther CPU cooler, while keeping the dimensions to a minimum.
The 120 mm fan with PWM connector can be controlled automatically by every modern mainboard in the market to keep the noise to a bare minimum. This cooling unit also features transparent red blades along with red LEDs. Prolimatech has also included a second set of clips, allowing the installation of another such fan for a push/pull configuration, further raising the performance bar on this cooler. Also part of the package is the award winning PK-1 thermal past and the very sturdy mounting kit with backplate for Socket 1155, 1156, AM2, AM2+ and AM3.
- Dimensions (with fan): 130 x 158 x 73 mm
- Heatpipes: 4x Ø 6 mm
- Fan: 120 mm (Red LED)
- Fan Noise: (29,1 dB(A)
- Fan RPM: 1.600 U/min +-10%, max.
Was £37.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
Arctic Silver 5 Thermal Compound (12g) @ £14.99 inc VAT
Introducing Arctic Silver 5 With its unique high-density filling of micronized silver and enhanced thermally conductive ceramic particles, Arctic Silver 5 provides a new level of performance and stability. Now available at Arctic Silver dealers worldwide, Arctic Silver 5 is definitely The New Reference. Arctic Silver 5 is optimized for use between modern high-power CPUs and high performance heatsinks or water-cooling solutions. Arctic Silver 5 uses three unique shapes and sizes of 99.9% pure silver particles to maximize particle-to-particle contact area and thermal transfer.
Was £19.99 Inc. VAT
Only £14.99 inc VAT.
ORDER NOW
Was £72.99 Inc. VAT
ORDER NOW
Was £89.99 Inc. VAT
ORDER NOW
<br>
<br>
<br>
<br>
Was £44.99 Inc. VAT
ORDER NOW
- Aluminum fins<br>
Was £26.99 Inc. VAT
ORDER NOW
Was £37.99 Inc. VAT
ORDER NOW
Was £19.99 Inc. VAT
ORDER NOW
