- 20 Jul 2009
- The bleak North East arm pit of Britain
We have some absolutely fantastic products on offer with these categories for this weekend.
Internal hard drives from both Western Digital and Samsung
Caddies and accessories from Akasa
External drives from Samsung in the form of the G3
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £72.98 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
- Backwards compatible with SATA-II
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: 7200RPM
- Warranty: 5 Years
Was £79.99Inc. VAT
Only £72.98 inc VAT.
ORDER NOW
Western Digital Caviar Black 640GB SATA 6Gb/s 64MB Cache - OEM (WD6402AAEX) @ £51.98 inc VAT
- Capacity: 640GB
- Cache: 64MB
- Warranty: 5 Years
Was £58.99 Inc. VAT
Only £51.98 inc VAT.
ORDER NOW
Samsung SpinPoint MP4 500GB 7200RPM SATA-II 16MB Cache - OEM (HM500JJ) @ £43.99 inc VAT
The combination of spin speed, the faster the cache size double and improved caching algorithms provides approximately 30% increased performance with speeds of 7200 rpm to 5400 speed. Performance optimization is that players, multitasking and enthusiastic users aspire from their computer systems. The Samsung Spinpoint MP4 player has a memory buffer of 16MB and is available in 250 GB to 640 GB capacity. Deliveries of new cars Samsung Mobile will be available to key OEM April 2010. Historically, high performance and fast speed means that the HDD operation ran the risk of excessive vibration, negative effects on the overall reliability. The design of the Samsung Spinpoint MP4 improved engine reduces the risk of imbalance of the disk and improves stability during read / write, compared to the previous model Samsung 7200. The Samsung Spinpoint MP4 features speed 7200 rpm, SATA 3.0Gb / s and Native Command Queuing functions for advanced performance. Equipped with Samsung technology exclusive dynamic balancing, the overall stability of the disk and the reliability has been optimized for high-performance solution. SilentSeek owners of Samsung and Tehnolog NoiseGuard are incorporated in the drive to offer ultra quiet operation.
- Capacity: 500 GB
- Interface: SATA 3.0Gbps
- Buffer DRAM Size: 16 MB
- Rotational Speed: 7,200 RPM
** NEW!! **
Only £43.99 inc VAT.
ORDER NOW
Samsung SpinPoint MP4 640GB 7200RPM SATA-II 16MB Cache - OEM (HM640JJ) @ £50.99 inc VAT
- Capacity: 640 GB
** NEW!! **
Only £50.99 inc VAT.
ORDER NOW
Akasa DuoDock Docking Station @ £25.99 inc VAT
DuoDock is a PC hard drive docking station offering greater flexibility than traditional external enclosures. Designed to sit on your desk enabling you to quickly read and write data to SATA drives. Simply place a drive into the Duo Dock and off you go! Make use of your spare SATA hard drives both 2.5” notebook or 3.5” desktop (all capacities). Chose you favorite PC connection: USB provides universal support and full hot swapping feature; eSATA delivers blazingly fast data transfer up to 3.0 Gb/s. Blue LED base with on/off switch can provide stylish illumination.
- Docking station for notebook and desktop drives
- Designed for 2.5” and 3.5” SATA hard drives
- HDD interface SATA
- Connection interface eSATA, USB 2.0
- Max data transfer rate 3Gb/s (eSATA) and 480Mb/s (USB2.0)
- Power adapter AC input 100-240V,DC output 12V (2A)
- Supports Windows 2000/ XP/ Vista / 7 and Mac OS X
- Dimensions: 140 x 108 x 71mm
Was £28.99 Inc. VAT
Only £25.99 inc VAT.
ORDER NOW
Akasa Dual 2.5" SSD/HDD Mounting Kit @ £4.99 inc VAT
This mounting kit allows you to install two 2.5" SSD/Hard Drives into a standard 3.5” drive bay of a PC case. Introduce new technology high-speed SSD (solid state drives) or make use of laptop HDD in your PC. High-grade aluminium enables rapid heat dissipation.
- 2x 2.5" SSD/HDD Compatible
- 100% aluminium for rapid heat dissipation
- Fits in 3.5" PC bay
Was £5.99 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
Akasa Elite eSATA/USB 2.0 3.5" Hard Drive Enclosure (AK-IC010-BK) @ £19.99 inc VAT
This élite enclosure enables external use of 3.5” SATA hard drives with style on the go or elegantly located on the desk with provided footstand. It is a Plug & Play device, which gives you a connection choice between very convenient USB 2.0 allowing easy access to your files whenever and wherever or ultra fast eSATA. Leather finish aluminium body with brushed aluminium fascia panels and polished edges define this luxury enclosure, which goes way beyond classic practicality.
- Leather finish with brushed aluminium fascia
- Suitable for 3.5” SATA I/II and SSD hard disk drives
- eSATA and USB2.0 connection with auto mode switching
- Plug-and-play - no drivers installation required
- Blue LED power and data transfer indicator
- Strong aluminium body for heat dissipation and quiet operation
- Powered from mains
Was £25.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Samsung G3 Station 2.0 TB External hard drive @ £83.99 inc VAT
Package Contents
- Model: G3 Station external hard drive
- Accessory: AC adapter and power cord,USB cable (120cm)
- Capacity: 2.0 TB
- Operating Systems: Windows, Mac (1)
- Color: Cobalt Black
- Interface: USB 2.0
- Data Transfer Rate: 480Mbps
- Temperature / Operating: 5C to 40C
- Temperature / Non-operating: 20C to 65C
Physical Dimensions
- Height ( Max ): 133.8 mm (5.27 inches)
- Width: 47.0 mm (1.85 inches)
- Length: 180.6 mm (7.11 inches)
- Weight (Max): 0.89 Kg (1.96 pounds)
Was £91.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
- Capacity: 1TB
- Cache: 64MB
- Warranty: 5 Years
Was £79.99Inc. VAT
ORDER NOW
- Capacity: 640GB
- Cache: 64MB
- Warranty: 5 Years
Was £58.99 Inc. VAT
ORDER NOW
- Capacity: 500 GB
** NEW!! **
ORDER NOW
- Capacity: 640 GB
** NEW!! **
ORDER NOW
Was £28.99 Inc. VAT
ORDER NOW
Was £5.99 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
Was £25.99 Inc. VAT
ORDER NOW
Package Contents
- Capacity: 2.0 TB
Physical Dimensions
Was £91.99 Inc. VAT
ORDER NOW
