- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Pianos and rodents time now with round 7!
Razer DeathAdder Respawn 3500 DPI Xtreme Precision Gaming Mouse - Retail @ £43.99 inc VAT
The Razer DeathAdder is the weapon of choice for gamers seeking a combination of comfort and unbridled gaming precision. Enjoy extended gaming sessions in comfort with its right-handed ergonomic form factor crafted for the world of competitive gaming; and when the difference between victory and defeat is determined between heartbeats, the 3500dpi Razer Precision 3.5G infrared sensor translates your every movement into frags with pinpoint accuracy.
- 3500dpi Razer Precision™ 3.5G infrared sensor
- Ergonomic right-handed design
- 1000Hz Ultrapolling™ / 1ms response
- Five independently programmable Hyperesponse™ buttons
- On-The-Fly Sensitivity™ adjustment
- Always-On™ mode
- Ultra-large non-slip buttons
- 16-bit ultra-wide data path
- 60–120 inches per second and 15g of acceleration
- Zero-acoustic Ultraslick™ Teflon feet
- Gold-plated USB connector
- Seven-Foot, lightweight, braided fiber cable
- Approximate size: 128mm (length) x 70mm (width) x 42.5mm (height)
Was £54.99 Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Razer Naga 5600DPI MMO Laser Gaming Mouse @ £56.99 inc VAT
The Razer Naga is the ultimate Massively Multiplayer Online Gaming mouse that shifts the balance between keyboard and mouse by putting an unprecedented number of in-game commands in one place. A multi-button thumb grid and Razer’s MMO game interface add-on combine to place every command you need in the palm of your hand. An ergonomic form shaped to maximize ease of use lets you game in comfort for hours on end. With the Razer Naga, you will Get Imba.
- 5600dpi Razer Precision 3.5G Laser Sensor
- 1000Hz Ultrapolling™ / 1ms response time
- 200 inches per second max tracking speed
- 17 MMO-optimized buttons (including 12 button thumb grid)
- Optional MMO-specific software AddOns
- Unlimited character profiles with AddOns
- Approximate size: 116L x 69W x 41.6H (in mm)
Was £69.99 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
Qpad MK-85 LED Pro Backlit Mechanical Gaming Keyboard - UK Layout @ £119.99 inc VAT
Unlike your average keyboard, that functions through rubber domes, forcing you to press each key all the way down in order for the stroke to register, the MK-85 feature true mechanical switches with unmatched accuracy and feel. No more pressing with full-force in order to activate the keys.The QPAD keyboard will respond to your every stroke in an instant.
Other boards normally have a short life span and wear out quickly, resulting in unresponsiveness, delays and a dull, clunky feel to the keys. The key switches on MK-85 are built to last 50 million strokes, and the QPAD mechanical key technology provides distinct feedback and puts you in absolute control. The travel distance of the keys is set to 4mm with an actuation point at 2mm.
For gamers, it’s all about the feel and functionallity and that is where the QPAD MK-85 truly shines. With a full size keyboard layout in 3 sections, gaming profiles, macro recording, mechanical key switches, media keys and full N-Key roll over via USB, it’s the perfect gaming keyboard. Nuff said...
- Key switch: Cherry MX mechanical switch technology
- Cherry Red Switches
- N Key Roll over: Full N-Key roll over via USB
- Key strokes: 50 Million
- Lighting: Individual LED backlight on every key for enhanced visuals
- Lighting features: Four levels of brigthness allow you to locate keys easily
- Connectors: Gold plated USB connectors for extremly low latency
- Media keys: Media keys for volume control, play, pause and skip tracks
- USB Hub: Two high speed USB 2.0 ports
- Audio ports: 3.5mm headphone-out and microphone-in jacks
- Cable: 1.8 meter braided cable
- Extras: 4 extra orange key caps and key cap puller
- Dimensions: Keyboard: 44,8 x 14,9 x 3,5 cm (17,6 x 5,8 x 1,37 inch)
- Wrist pad: 44,8 x 6,6 x 1,7 cm (17,6 x 2,48 x 0,66 inch)
- Weight: 1.27 Kg (2.8 LBS)
- Warranty: 2 year
- Software: Customizable profiles, programmable keys and macro recording
- Supports: Windows XP, Vista, 7
Was £129.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Saitek Cyborg V7 Illuminated Gaming Keyboard @ £49.99 inc VAT
Witness the true power of Cyborg and take your gaming to the next level with the Cyborg Keyboard range. When performance is key, customization is vital, and losing is not an option, only Cyborg brings the power you crave.
- Touch-sensitive, backlit dashboard Control Panel – Configure your lighting, media and volume controls with the brush of a finger.
- Cyborg Mode – Instantly disable the Windows® keys and change the color and brightness of your gaming keys at the touch of a button.
- 12 programmable ‘Cyborg’ keys – Store your favorite macros for buying equipment, activating abilities or just for initiating your favorite trash talk.
- Powerful ST Programming Software – Create profiles for each game that you play in order to save different button configurations.
- Hard wearing, metal-plated key caps in key gaming areas are designed to withstand the punishment that pro gamers demand.
Was £54.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Corsair Vengeance M90 5700dpi Laser Gaming Mouse @ £49.99 inc VAT
You get maximum precision and response from the Avago ADNS-9500 LaserStream™ gaming sensor, even on high resolution displays. Outpace and dominate opposing players with less accurate or slower gaming mice.
The 15 fully programmable buttons are arranged and tuned for intuitive operation without compromising your grip. You get almost effortless access to your frequently-used abilities, macros, button combinations, and spells. Keep your focus on the game, and not the buttons.
The strong aluminum frame is the secret to low weight, high rigidity, and optimal mass distribution. The texturized, soft-touch surfaces are designed for comfort even after extended hours of gameplay. In short... it's designed to simply feel right.
Create up to 50 profiles and share, import and export macros with the Vengeance gaming mouse software. It's a free download at corsair.com.
Play multiple games, with multiple character types? Store up to 6 profiles in memory on the Vengeance M90 laser gaming mouse, so you can easily save your character profiles, favorite macros and frequently used keys. Enjoy the convenience of always having your profiles and preferences even if you switch PCs.
Instantly adjust DPI for precise control when quick changes are needed between different sensitivity settings... all with the simple touch of a button.
When the action is fast and furious, you are constantly moving and repositioning your mouse. The M90 includes lift detection provides high precision tracking and reliable cursor placement even when lifted off of the mousing surface.
The solid metal, rubberized scroll wheel doesn't just feel great — it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time.
- 5700 DPI Avago ADNS-9500 LaserStream Gaming Sensor
- Adjustable DPI in 100 DPI increments
- 1000Hz/500Hz/250Hz/125Hz — 1msec/2msec/4msec/8msec response time — user selectable
- Tracking rate of up to 165 inches per second, up to 30g acceleration, automatic frame rate control
- Adjustable lift distance
- Five selectable levels to fit your play style
- Surface quality detection
- 15 programmable buttons
- Nine ergonomically placed, side-mounted programmable buttons
- Comfortable ergonomic design with soft-touch surfaces and grip improving textures
- Omron left and right click switches rated for eight million operations
- 48KB of on-board memory for storing up to six "on the go" profiles with active profile LED
- Aluminum metal frame and base for improved rigidity and mass distribution
- Solid metal, weighted scroll wheel with rubberized scroll surface for improved finger traction control and feel
- Ultra Low Friction PTFE pads for smooth performance and accurate gliding
- USB Connector with gold plated contacts
- 1.8m lightweight non-tangle cable
Was £59.99 Inc. VAT
ORDER NOW
Logitech G300 Gaming Mouse (910-002489) @ £23.99 inc VAT
The Logitech® Gaming Mouse G300 gives you more power, more control and more loot. Nine programmable controls let you move keyboard commands to buttons that are in easy reach. Onboard memory allows you to store up to three game or player profiles on the mouse. You can move it between computers without having to reconfigure it every time you do.
- Ambidextrous Design
- Corded
- Custom-Color LEDs
- Ergonomic
- Forward/Back Buttons
- Full-Speed USB
- Gaming
- High-Definition Optical Sensor
- Optical Sensor
- Programmable Buttons
- USB connection
Was £29.99 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Roccat Kone V2 Max Customisation Gaming Mouse @ £27.98 inc VAT
Stuffed with technology and design innovations, the gaming mouse ROCCAT™ Kone is the only tool to unleash your hidden skills and develop your existing ones to the max. The precise Pro-Aim Gaming Sensor effectively reduces Pick-Up-Flight. It is accompanied by a high-end 6.4 megapixel sensor measuring with 7080 frames per second, loss-free up to a velocity of 20G. 1ms response time, 1000Hz polling rate and the adjustable resolution up to real 3200dpi give you the competitive edge to improve your aiming skills.
- 3200 DPI Pro-Aim Gaming Sensor
- TCU: Tracking Control Unit
- Integrated Turbocore (internal CPU built into the mouse)
- Onboard Memory (128KB) allowing you to save up to 5 gaming profiles
- Ergonomic Hybrid Shape
- Customizable Light System: 5 LED's capable of displaying the full spectrum of colours
- Customizable weighting (5g, 10g, 15g and 20g weights)
- NEW IMPROVED SCROLL WHEEL WHICH CAN TAKE UPTO 1.5KG MORE LOAD COMPARED TO THE ORIGNAL ROCCAT KONE MOUSE
Was £34.99 Inc. VAT
Only £27.98 inc VAT.
ORDER NOW
Logitech K120 Keyboard (920-002524) @ £6.98 inc VAT
The Keyboard K120 for Business is the budget-friendly keyboard that's built to last. You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound, and standard layout with full-size F-keys and number pad. This spill-resistant keyboard* also features a sleek yet sturdy design, a plug-and-play USB connection and easy-to-read keys.
- You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound to minimise distractions. The industry standard layout with full-size F-keys and number pad helps you be more productive and supports keyboard templates.
- With its thin profile that keeps your hands in a more neutral position, spill-resistant design*, durable keys that can withstand up to 10 million keystrokes** and sturdy, adjustable tilt legs, this sleek keyboard not only looks and feels good – it's built to last.
- Plug-and-play simplicity saves you time and resources – you just plug it into a USB port and start using it right away without software.
- The bold, bright white characters make the keys easier for everyone to read – including those with less-than-perfect vision. They're less likely to wear off, too.
- You get the high quality and reliability that's made Logitech® the global leader for keyboards and mice at a price you can afford – plus a 3-year manufacturer's guarantee.
Was £9.99 Inc. VAT
Only £6.98 inc VAT.
ORDER NOW
- Always-On™ mode
Was £54.99 Inc. VAT
ORDER NOW
Was £69.99 Inc. VAT
ORDER NOW
- Warranty: 2 year
ORDER NOW
Was £54.99 Inc. VAT
ORDER NOW
Was £59.99 Inc. VAT
ORDER NOW
- Corded
- Custom-Color LEDs
- Ergonomic
- Full-Speed USB
- Gaming
- Optical Sensor
- USB connection
Was £29.99 Inc. VAT
ORDER NOW
Was £34.99 Inc. VAT
ORDER NOW
Was £9.99 Inc. VAT
Only £6.98 inc VAT.
ORDER NOW
