** Weekend Deals - ROUND 8 - Chassis **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Now onto the round known as cases :) Some great bargains to be had here!
Anidees AI-6B Midi-Tower Case - Black @ £89.99 inc VAT
The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior, with a brushed aluminum centre. In between lie a set of stealthy and concealed air vents, which should ensure good cooling.
This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.
Although only an adapter factory setting of one of three 5.25-inch slots at Al-6 is, but those frames can be conveniently buy more if needed. The lid of the clear line is continued by the I/O panel which is inserted inconspicuously. Two USB 3.0 ports that are present in addition to audio connectors and four USB 2.0 and are connected internally.
Under the removable cover part you will find a very good mesh surface, which ensures that a radiator with a size of up to 280 mm which can optimally cool with a good deliver fresh air. Alternatively, it is also just two 140s or 120s fan positioned there. The same applies to the front, where two fans of both formats can be accommodated, while the rear has only one 120-mm fan space.
Dimensions: 207 x 509 x 527 mm (W x H x D)
Material: steel, aluminum
Weight: 11 kg
Color: Black
Form Factor: ATX, Micro ATX, Mini-ITX
Front Cooling: 1x 140 / 120 mm (front, 120 mm optional)
Rear Cooling: 1x 120 mm (rear) / 1x 140 / 120 mm (front optional)
Top Cooling: 2x 140 / 120 mm (lid, optional)
Filters: Front & Back
Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 2.5 inch (internal)
Power Supply: Standard ATX 1x (optional)
Expansion Slots: 8 (without tools)
I / O Panel: 2x USB 3.0 / 4x USB 2.0 / 1x each Audio In / Out
Maximum graphics card length: 428 mm
Features: Elements made of brushed aluminum
- Cable Management
HDD and power supply decoupling
- Removable hard disk cages
Was £99.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
CM Storm Trooper Full Tower Gaming Case - Black @ £94.99 inc VAT
nonl2brCM Storm unleashes a truly magnificent feat of engineering into an arena that represents the future of warfare; the Trooper full-tower chassis. Capable of lightning fast redeployment, it’s the first in its class to include an ultra-strong carrying handle; allowing a gamer to travel with the finest system configurations available with relative ease. CM Storm Trooper includes features that are most coveted by gaming enthusiasts in that it has full dust filter coverage, a fan controller, an external SSD drive hot-swap dock and two uniquely designed modular hard drive cages. These features give CM Storm Trooper the ability to adapt to workstation or water-cooled gaming configurations easily.<br>
CM Storm Trooper exterior features a damage-resistant rubberized coating that will protect the case during transport. Things heat up as gaming becomes more intense. The included front panel connections and controls provide a user with the ability to make on-the-fly changes to fan speed and case LEDs while USB 3.0 and 2.0 ports, and audio connections are also provided as an added means of convenience. This is topped off by a 2.5” HDD/SSD X-dock that makes mounting extra drives as easy as loading a Blu-ray/DVD. Changing settings at a moment’s notice becomes a simple matter of a quick button press with CM Storm Trooper.<br>
CM Storm Trooper contains two modular HDD cages which can hold 4HDDs and a120mm fan for cooling each. These modular units can be rotated, front to back, side to side or removed altogether. CM Storm Trooper is the first chassis to allow fully modular hard drive configuration with no modification required. CM Storm Trooper can be equipped with multiple watercooling radiators.<br>
Creatively mounting a vertical water-cooling radiator is possible with the removal of the hard drive cages and panels. CM Storm Trooper has nine expansion slots providing support for multi-GPUs in SLI or Crossfire, space for up to 14 hard drives, and a motherboard tray that supports up to XL-ATX. The Trooper is an ideal mobile arsenal to house and transport the most advanced system and cooling setups.<br>
A professional cable management look is possible by utilizing the myriad cable tie zones and cable management holes available in the CM Storm Trooper. Smarter and larger placements of these areas allow for efficiently routing cables directly to their intended destinations. In an effort to reduce installation times, a great number of hardware can be mounted tool-free via the use of the included locking mechanisms or trays. A very large CPU heat sink retention hole has been placed in the motherboard tray to allow it to be compatible with most types of CPU and motherboard layouts. Prepare for the unexpected as seasoned operative would with a hidden drawer placed behind a false panel. The bottom panel removes to reveal a storage drawer to keep private effects safe from prying eyes until they are needed.<br><br>
- Material: Steel body, Front Mesh / Plastic bezel<br>
- Dimensions: 250 x 605.6 x 578.5 mm (9.8 x 23.8 x 22.8 in)<br>
- M/B Type: Micro-ATX, ATX, XL-ATX<br>
- 5.25" Drive Bays: 9<br>
- 3.5” Drive Bays: 8 (converted from 5.25” bay by two 4-in 3 HDD modules)<br>
- 2.5” Drive Bays: 13 (converted from 5.25” bay by two 4-in 3 HDD modules)<br>
- Front Cooling: 120 mm LED fan x2 (1200 RPM, 17dBA)<br>
- Top Cooling: 200 mm fan x 1 (1000 RPM, 23 dBA)<br>
- Rear Cooling: 140 mm fan x1 (1200 RPM, 19 dBA) / (converted to 120 mm fan)<br>
- Bottom Cooling: 120 mm fan x 2 (optional)<br>
- Side Cooling: 120 mm fan x 2 (optional)<br>
- Expansion Slots: 10<br>
- I/O Panel: USB 3.0 x 2 (internal), USB 2.0 x 2, e-SATA x 1, Audio In and Out ( Supports HD audio)<br>
- Maximum Compatibility: CPU cooler height: 186 mm / 7.3 in / GPU card length: 322 mm / 12.7 in<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/Kfpv_d73CFU" frameborder="0" allowfullscreen></iframe>
Was £109.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Corsair Carbide 300R Mid Tower Case - Black @ £54.98 inc VAT
The Carbide Series™ 300R is a compact expression of the Corsair philosophy: great systems begin with a great case. Open the easy-access side panel to find a builder-friendly design with three tool-free optical drive bays and four tool-free hard drive bays with integrated 2.5” SSD compatibility. There’s room for extra-long graphics cards, and the matte black interior really shows off your gear. Finish off your build with a cable routing system that keeps wires and cables out of sight and out of the airflow path for a clean, uncluttered look.
The 300R keeps your hardware cool with amazing airflow, including a 140mm front intake fan and a 120mm rear exhaust fan. There’s room to add five additional fans, including dual side-panel fan locations that can deliver cool air directly to your graphics cards. And, the dust filters are removable for easy maintenance. Features like these make the Corsair Carbide Series 300R the foundation of your next great system.
- Room for graphics cards up to 450mm long
- USB 3.0 front panel connectors
- Built-in compatibility for SSDs in the four hard drive bays gives you the flexibility you need
- Keep your system cool with up to 7 fan mount locations
- Easily accessible dust filters keep the cool air flowing over your valuable components
- Install or upgrade your CPU heatsink quickly with the easy-access backplate cutout
- Optimize airflow and keep your system neat and tidy using the intelligent cable management system
- Drive Bays: 3 x 5.25" Drive Bays and 4 x 3.5"/2.5" Drive Bays
- Cooling: 1 x 140mm intake fan and 1 x 120mm exhaust fan
- Expansion Slots: 7
- Motherboard Support: ATX & mATX
- Front I/O: 2 x USB3.0 and 2 x Audio
- Dimensions: 19.1" x 8.3" x 17.7"
Was £59.99 Inc. VAT
Only £54.98 inc VAT.
ORDER NOW
Fractal Design Define Mini Computer Case - Black @ £64.99 inc VAT
As the name implies, Define Mini is the smaller sibling of the acclaimed and award winning Define R2/R3 case. Being a Micro ATX version of Define R2/R3, it offers a number of interesting functions with a very stylish appearance. It's a case focused on low noise level, without neglecting other important features such as cooling, expandability and ease of use. The Define Mini excels in including a lot of features in a small size!
The patent pending feature ModuVent™, in which you can choose whether to have fan slots in side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones.
The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of six(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it.
- 6 x 3.5 inch HDD trays, compatible with SSD!
- 2 x 5.25 inch bays, with 1x 5.25 3.5 inch converter included
- On top of front panel: 2 x USB2, 1 x USB3 and Audio I/O
- Removable filter below PSU (No PSU included)
- M/B compatibility: Mini ITX and Micro ATX
- 4+1 expansion slots with sleek white painted brackets
- Supports graphic cards with lengths up to ca 260mm when removable HDD-bay is in place
- Supports graphic cards with lengths up to ca 400mm when HDD-bay is removed
- Supports CPU coolers with height of ca 165mm
- Supports PSU's with a depth of maximum circa 170mm, when using bottom 120/140mm fan location. - When not using the bottom 120mm fan location, the case supports also longer PSU's, typically 200-220mm.
Was £74.99[OLDPRICE] Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
NZXT Source 210 Midi Tower Case - Black @ £30.98 inc VAT
Gamers spend approximately £30 per game, buy X number of video game titles per year. You know what it’s like…it adds up very quickly. Sometimes gamers are starving college students, sometimes gamers have girlfriends; the green keeps flying away. NZXT’s Source 210 is here to provide the basic chassis to house your rig. It’s modest and contains the essentials for performance. It’s the chassis you can afford.
The Source Series is NZXT’s chassis line designed to be a starting block for first time builders or a stepping stone for those who want to upgrade their rig later on. Each chassis faithfully serves their purpose as an affordable, memorable part of your system building experience; it may just be a keeper.
- Bottom Mounted PSU – Positioned for the most effective PSU ventilation
- Wire Management Support – 20mm space for a neat and easy build
- Aluminum Textured Panel – Accents the chassis for a clean, modern look and feel
- Dual 120mm Front Intake – Takes advantage of front facing HDD bays for excellent airflow
- Maximum Cooling Potential – Eliminate heat by installing up to seven 120mm fans
- Also fits 2 x 120/140mm fan
- Dimensions: (W x H x D) 195mm x 440mm x 495.5mm
- VGA Clearance Maximum: 230mm w/ hard drive, 330mm w/o hard drive
- CPU Heatsink Support: 160mm
- Front Cooling: 2 X 120mm
- Rear Cooling: 1 X 120mm @ 1200rpm (included)
- Top Cooling: 2 X 120/140mm
- Bottom Cooling: 1 x 120mm
- Drive Bays: 3 External 5.25" DRIVE BAYS / 8 Internal 3.5" HDD Drives
- Motherboard Support: ATX, MICRO-ATX
- Front I/O Ports: 1 x Standard Audio/Mic, 2 x USB 2.0
Was £36.99 Inc. VAT
Only £30.98 inc VAT.
ORDER NOW
NZXT Tempest 410 Midi Tower - Black @ £52.99 inc VAT
An aggressive cooling solution forged for your rig, the Tempest 410 Midtower completes your fine-tuned machine by taking advantage of the airflow required for the enthusiast’s overclocking needs. The Tempest legacy expands its maximized ventilation through the extra-large honeycomb mesh design, dual radiator support, and dual touch powered front fans. If you are looking for a new cooling edge for your gameplay, Tempest 410 will bring you the results of epic win.
- Large honeycomb steel mesh design for optimal airflow
- Dual radiator support for all-in-one liquid cooling solutions
- Latest Audio, USB 2.0, and USB 3.0 internal support
- Top storage compartment and cable routing for convenience
- Innovative dual 120mm side fan slot or adjustable single fan slot to target hot spots in the case
- Dual touch powered 120mm front fans equipped with easily removable filters for easy maintenance
- Dimensions: (W x H x D) 215 x 481 X 496mm
- VGA Clearance Maximum: 315mm w/o HDD, 290mm w/ bracket, 250mm w/ HDD installed
- CPU Heatsink Support: 170mm
- Front Cooling: 2 X 120mm @ 1200rpm (1x included)
- Side Cooling: 2 X 120mm
- Rear Cooling: 1 X 120mm @ 1200rpm (1x included)
- Drive Bays: 3 External 5.25" Drive Bays / 8 Internal 3.5"/2.5" Slots
- Screwless Rail Design
- Motherboard Support: ATX, MICRO-ATX, MINI ATX, FLEX ATX, MINI ITX
Was £59.99 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
OcUK Galaxy III Tower Case - Black (450W PSU) @ £31.99 inc VAT
OcUK Galaxy III gaming case with a 450W power supply and a well designed acryllic side window.
- External Drive Bays: 4 x 5.25" and 2 x 3.5"
- Internal Drive Bays: 4 x 3.5" H.D.D.
- See Through Window Side+LED FAN
- ATX Form Factor 12" x 10.5" or smaller
- USB2.0 + AUDIO
- Dimensions :410 x 200 x 480mm (HxWxD)
- Standard ATX 7 slots
- ATX 12V 450 watts power supply included (with SATA PIN).
- 0.7mm SECC
- bubble-Tube lights
- One 90mm Blue LED Fan supplied on side door
- 2 x 80mm spaces for intake fans
- 1 x 120mm rear exhaust fan space
Was £34.99 Inc. VAT
Only £31.99 inc VAT.
ORDER NOW
Xigmatek Asgard III Windowed Gaming Case - Black @ £31.99 inc VAT
"Asgard-III" - The Property of Æsir and castle of Odin. As the country of Gods, the inviolable Asgard-III is the world’s first black coating entry-level chassis - milestone. Furthermore this chassis is supplied with 1 x 120mm preinstalled black fan, and 3 more fans can be mounted in different areas for best possible airflow. 4 x 5.25" bays will be able to house all your optical drives, but also 5 trays for your 3.5” HDDs are available so you can feel free by "DIY". Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for pc beginners.
- Screw-less tooling for 5.25” bay installation.
- Screw-less tooling for expansion slot installation.
- Screw-less tooling for 3.5” bay installation.
- Preinstalled 120mm front fan
- Supports 4 cooling fans in total.
- Back window for easy CPU cooler back plate.
- Dust filter behind front panel for intake airflow.
- Dimension: 185(W) x 475(D) x 408(H) mm, 0.6mm thickness SGCC.
- Drive Bay: 5.25” External x 3 (Tool-free)
- 3.5” External x 2 (Tool-free)
- 3.5” Internal x 5 (Tool-free)
- Expansion Slot: 7 slots (tool-free), 290mm free add-on card length.
- Front Fan: 80/90/120mm x 1 fan is available.
- Rear Fan: Preinstalled 120mm black fan x 1 (80/90mm fan is available)
- Side Fan: 80/90/120mm x 2 fans are available.
Was £36.99 Inc. VAT
ORDER NOW
Silverstone TemJin TJ10B-W Windowed Big Tower Case - Black (SST-TJ10B-W) @ £199.99 inc VAT
The Temjin TJ10 takes another step forward in perfecting the fusion of classic tower styling with the latest in chassis technology. While structurally the same, the TJ10 adds numerous new details to set itself apart from the TJ09. The unique mid-section air duct, which was created to bypass the hard drive cage with 120mm fan to draw cool air from outside of the chassis, can now offer additional support points for extended length graphics cards. The effective cooling layout provided by the all 120mm fan design has been tweaked to further encourage more airflow. For enthusiasts that prefer having a front door with outstanding chassis design and finish, the Temjin TJ10 is a must have.
- Material: Aluminum front panel/door, 2.0mm aluminum body
- Motherboard Support: SSI-EEB, Extended ATX, ATX, Micro-ATX
- Drive Bays: 5.25" x 4 / 3.5" x 7
- Front Cooling: 1 x 120mm fan (optional)
- Rear Cooling: 1 x 120mm exhaust fan, 1200rpm, 21dBA
- Side Cooling: 1 x 120mm mid-section fan, 1200rpm, 21dBA
- Top Cooling: 2 x 120mm fans (optional)
- I/O Ports: USB2.0 x 2 / IEEE1394 x 1 / audio x 1 / Mic x 1
- Supports 12" GPU's
- Dimensions: 207 mm (W) x 521 mm (H) x 644 mm (D)
Was £229.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Silverstone Precision PS02 Midi Case - Black (SST-PS02B) @ £34.99 inc VAT
For SilverStone engineers, innovation is more than feature improvements; it is about improving total user experience. The Precision series PS02 is designed for users that appreciate quality computing experience. With a heritage of conservative premium tower chassis as the basis, the PS02 follows the same styling direction to achieve a modern, classic look. The up-side down power supply layout design and flexible drive storage options enable PS02 to support a wide selection of components. For those requiring a quality enclosure with great styling, the PS02 is an excellent choice.
- Classic front panel styling
- Mid-size tower chassis for all around integration
- Excellent cooling performance
- Highly flexible drive storage options
- 4x 5.25" and 6x 2.5" bays
- Front I/O Ports: 2x USB2.0 and 2x Audio
- Dimensions: 200mm x 438mm x 483mm (W x H x D)
Was £38.99 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
Have OcUK ever had the Silverstone TJ08-E in stock? Looking at it for my new build and was a bit surprised to not find it on the site, seems like a pretty popular case from my research.
I'm building next week so don't hold it against me for going elsewhere for the TJ08-E - getting my mobo/ram/cooler/psu/accessories from you guys, though would have got the TJ08-E from you too had you had it ;)
