Weekend Deals - Round 8 - Enclosures
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
All these component deals need a new home. These enclosures offer the perfect house for all your other new shiny items. And if you aint bought anything else. Make your dusty old case new and shiny anyway.
Coolermaster HAF X Gaming Tower Case - Black (RC-942) @ £131.99 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Bottom mounted PSU
Was £142.97 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
Coolermaster HAF 912 Plus Case - Black @ £57.98 inc VAT
Cooler Master adds another new member to the HAF series, the HAF 912 Plus. To carry the mission of providing the best thermal solutions, HAF 912 Plus supports two 120 mm for external radiator and high-end CPU coolers. Furthermore, the spacious interior accommodates two 200mm fans and two-- 120mm fans for better and superior airflow yet, enough to fit 12 devices and high-end GPUs such as Radeon HD5970 and Nvidia GTX 480.
- Superior cooling performance support up to two 200 mm and two 120 mm fans
- Front 200mm fan with brilliant Red LED provides the best airflow to HDDs
- Removable 3.5”HDD cage provides enthusiasts more convenient installation
- Customized neat cable management
- Dimensions 230 x 480 x 496 mm (WxHxL)
- Weight: 8,45 kg
- Motherboard Support: ATX, Micro-ATX
- Front Cooling: 1x 200 mm (19 dB(A), 700 RPM, Red LED) or 2 x 120mm fans (optional)
- Top Cooling: 1x 200 mm or 2 x 120mm fans (optional)
- Rear Cooling: 1x 120 mm (17 dB(A), 1.200 RPM)
- Side Cooling: 1x 140 / 120 mm (Optional)
- 5.25" Drive Bays: 4
- 3.5" Drive Bays: 7
- 2.5" Drive Bays: 4
- Expansions Slots: 8
- Front I/O Ports: 2x USB 2.0 / 1x eSATA/ 1x Audio In/Out
- VGA Card Size: Up to 39 cm
Was £66.99 Inc. VAT
Only £57.98 inc VAT.
ORDER NOW
Antec 100 One Hundred Ultimate Gaming Case - Black @ £41.99 inc VAT
Antec’s One Hundred is the gaming case that delivers high-end features at a price that won’t break the bank. Eight expansion slots provide exceptional expandability, and can accommodate multiple video cards. A sleek painted black interior with clean, perforated front bezel houses your components in style, while the four top USB ports with audio in/out and handy storage tray bring convenience and accessibility to the package. Finally, the bottom PSU mount, two included TwoCool™ fans and washable fan filter keep your system cool and quiet. Antec’s One Hundred provides a wealth of in-demand features while keeping you within your budget.
- Bottom-mounted power supply isolates heat and noise
- Perforated front bezel delivers maximum air intake
- Includes standard case lock slot for integrated anti-theft protection
- CPU cut-out allows for easy installation of CPU coolers
- Cable management compartment organizes cables discretely
- Convenient top accessory tray
- Cable management ties keep your case organized
- 6 x internal 3.5” HDDs
- 3 x external 5.25” HDDs
- 1 x internal bottom-mounted 2.5” SSD drive
- 8 expansion slots for plenty of flexibility
- Cooling system
- 1 x top special 140 mm TwoCool™ fan
- 1 x rear 120 mm TwoCool™ fan
- 2 x front 120 mm fans for HDDs (optional)
- 1 x side 120 mm fan for graphics cards (optional)
- Front ports: 4 x USB 2.0, Audio (AC’97 and HDA compatible) In and Out
- Washable air filter for quick, easy cleaning
- Motherboards: Mini-ITX, microATX, Standard ATX
- Power supply not included
- Dimensions: 480.5 mm (H) x 197.5 mm (W) x 477 mm (D)
Was £44.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Antec 902 Nine Hundred Two (V3) Ultimate Gaming Case (with USB3.0 Support) - Black @ £91.99 inc VAT
Antec’s popular and award-winning Nine Hundred gaming case became an instant favorite among gamers, delivering versatility, style and performance to establish itself as “The Ultimate Gaming Case.” Now Antec introduces the Nine Hundred Two, the next generation in premier gaming enclosures. Building on the tried-and-true designs of both the Nine Hundred and the powerful Twelve Hundred gaming cases, the Nine Hundred Two maintains popular features such as a perforated front panel, up to six variable-speed fans for maximum cooling, and a sleek, aggressive aesthetic. The Nine Hundred Two adds exciting improvements such as a top 200mm Big Boy TriCool™ fan now with blue LED, fan control knobs plus built-in washable air filters right in the front panel, and eight expansion slots for even greater versatility. Dominate your competition and maximize cool with the Antec Nine Hundred Two: “The Ultimate Gaming Case, Evolved.”
- 9 drive bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3 x 3.5" for HDD, or
- External 9 x 5.25"
- Advanced cooling system:
- 1 rear 120 x 25mm TriCool™ blue LED exhaust fan
- 1 top 200 x 30mm “Big Boy” TriCool™ blue LED exhaust fan
- 2 front 120 x 25mm special black blue LED intake fans with front speed control
- 1 side (Optional) 120 x 25mm fan mount
- 1 middle (Optional) 120mm fan mount
- Built-in washable air filters
- 8 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Front mounted I/O ports
- 2 x USB 2.0
- 1 x eSATA
- Audio In and Out (AC’97 and HDA compatible)
- Motherboard: Mini-ITX, microATX, Standard ATX
- No power supply included
Was £104.99 Inc. VAT
Only £91.99 inc VAT.
ORDER NOW
