Hi there
OK this little Mini-PC is a superb piece of kit, the price is truly mental, check this out:-
Zotac Z-Box SD-ID12 Intel Atom Mini PC @ £119.99 inc VAT
Introducing the ZOTAC mini-PC series – the perfect everywhere mini-PC for all your computing needs. Whether it’s your living room, kitchen, bedroom or office, the ZOTAC mini-PC series are perfect for all your needs and demands thanks to the miniature size and versatile placement options.
ZOTAC mini-PC series are powered by high-performance yet energy-efficient CPUs and GPUs that delivery plenty of computing power while consuming minimal amounts of energy for eco-friendly computing. The ZOTAC mini-PC series pack plenty of power and performance for your routine tasks such as web browsing, checking e-mail, word processing, video playback and other tasks.
Take the first step to living green with the eco-friendly and energy-efficient ZOTAC ZBOX SD-ID12 mini-PC powered by Intel® Atom™ technology combined with Intel® Graphics Media Accelerator 3150 graphics. The ZOTAC ZBOX SD-ID12 mini-PC delivers phenomenal performance and compatibility for a full Microsoft® Windows® 7 experience with Aero® user interface while maintaining best-in-class energy-efficiency.
The ZOTAC ZBOX SD-ID12 mini-PC is easy to master with only two thumb screws in place to unlock the internal expansion capabilities. Inside the ZOTAC ZBOX SD-ID12 mini-PC is space for a 2.5-inch SATA hard drive and 204-pin DDR3 DIMM module while USB 2.0, eSATA and a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) provide external expansion.
Features:-
- Intel® HyperThreading technology
- Intel® ClearVideo (SD) technology
- Microsoft® DirectX® 9 compatible
- OpenGL® 1.5 compatible
- Energy-efficient computing
Specifications:-
- Intel® Atom™ D525 CPU (1.8 GHz, dual-core)
- Intel® NM10 Express chipset
- Intel® Graphics Media Accelerator 3150 GPU
Internal Expansion:-
- 1x 2.5-inch SATA 3.0 Gb/s hard drive
- 2x 204-pin DDR3-800 SO-DIMM
Display Outputs:-
- HDMI (720p)
- HDCP compliant
- VGA
Front Ports:-
- Headphone/Audio out jack
- Microphone jack
- 6-in-1 Memory card reader (MMC/SD/SDHC/MS/MS Pro/xD)
- 1 USB 2.0 port
- WiFi LED
- Hard drive LED
- Power button
- Dimensions: Length: 7.40in - 188mm, Width: 7.40in - 188mm, Depth: 1.73in - 44mm
Rear Ports:-
- 1x eSATA
- 4x USB 2.0 ports
- 10/100/1000 Ethernet (RJ45)
- Digital S/PDIF output
- Power connector
Top Ports:-
- 1x USB 2.0 port
Inside the box:-
- ZOTAC ZBOX SD-ID12
- Power brick & cable
- VESA monitor mount (w/4 screws)
- Stand
- Warranty: 2yr
Was [£139.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
This is a crazy deal, remember this little PC can be attached to the rear of a VESA compliant monitor or makes an excellent little streaming box for movies. Such a great bargain, don't miss out!
Features:-
Specifications:-
Display Outputs:-
- HDMI (720p)
- HDCP compliant
- VGA
Front Ports:-
- Microphone jack
- 1 USB 2.0 port
- WiFi LED
- Hard drive LED
- Power button
Rear Ports:-
- 1x eSATA
- 4x USB 2.0 ports
- Power connector
Top Ports:-
- 1x USB 2.0 port
Inside the box:-
- Stand
- Warranty: 2yr
ORDER NOW
