Hi there
Right guys got some really good monitor deals for you. The first one is a 22" OcUK monitor which is built by Digimate and features DVI, a good panel for the price. The second is another OcUK monitor but this one a 23.6" which comes from the same factory that built the Samsung Cream monitors, so 2ms response time and great built quality. The final deal is a very special monitor from iiyama at a crazy price.
OcUK L-2266WD 22" Widescreen LCD Monitor - Black @ £99.99 inc VAT
The Digimate L-2262WD has an ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 700:1 contrast ratio and digital input there is no other monitor that can match the quality, value or performance.
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 1000:1
- Brightness: 300cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 170°/170°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 510.0mm x 448.0mm x 190.0mm
- Weight: 5.0kg
- Warranty: 3 Years On-Site
Only £99.99 inc VAT.
ORDER NOW
OcUK Cream 23.6" Widescreen LCD Monitor - Black @ £126.89 inc VAT
The OcUK Cream 23.6" monitor has an industry leading ultra-fast 2ms response time making it perfect for blur-free video and gaming. With it's 2000:1 contrast ratio and digital connectivity there is no other LCD that can match the combination of value and performance.
Features
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 5000:1
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Multimedia Speakers
- Warranty: 3 Years On-Site - Call (0870) 2485492 to arrange on-site swap out (8am-4pm)
Only £126.89 inc VAT.
ORDER NOW
Iiyama ProLite E2410HDSD 24" Widescreen LCD Monitor - Black @ £150.39 inc VAT
The new ProLite E2410HDSD-1 is the new 24” screen size to join the iiyama Eco-monitor range. Energy Star rated and using less than 1W in power management mode it is good for the environment yet still features the high specification you come to expect from iiyama. Combining an exceptionally fast 2ms response time, true 16:9 HD and 1920x1080 (2.1mega pixel) native resolution makes for improved colour range and depth in gaming and video and graphic applications. The E2410HDSD features 2 x 2W speakers and analogue and digital connectivity for flexibility across different platforms.
Features:-
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000:1
- Brightness: 250cd/m²
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 4.5kg
Only £150.39 inc VAT.
ORDER NOW
- Weight: 5.0kg
ORDER NOW
Features
ORDER NOW
Features:-
- Weight: 4.5kg
ORDER NOW
