WEEKEND ONLY DEALS - ROUND 2 Flash and Storage Accessories!
20 Jul 2009
The bleak North East arm pit of Britain
Round 2 of weekend deals kicks off with some lines on Flash and Storage accessories. Free shipping also applies to qualifying forum members :)
OcUK Value 2.5" to 3.5" Hard Drive Adapter @ £4.99 inc VAT
The OcUK Value 2.5" to 3.5" Hard Drive Adapter offers a simple solution for mounting 2.5" SSDs/Hard Drives within a 3.5" drive bay.
- Aluminium 3.5" Bracket
- Easily add a 2.5" SATA hard drive to your 3.5" slot on your PC
Was [£6.24] Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
Icy Box IB-267SK-B 2.5" SATA Trayless Mobile Rack @ £14.39 inc VAT
Icy Box 2.5" SATA HDD Enclosure to SATA host in 3.5" bay trayless with keylock
- Aluminium / plastic
- Super fast HDD installation/exchange without tray
- Supports 2,5" SATA HDD in a 3,5" bay
- Data transfer up to 3 Gbit/s
- HDD capacity unlimited
- Supports: Win98/ME/2000/XP/Vista
- LED for power and HDD access
- Key locl to prevent improper operation
- Special case for better heat evacuation
- Supports Hot Swap
Was [£16.33] Inc. VAT
Only £14.39 inc VAT.
ORDER NOW
Icy Box IB-AC602 3.5" Hard Drive Protection Box @ £4.74 inc VAT
Secure your data during transport against dust, falls and splash water damage. A simple protection with a great effect. The enclosure features two cushions at the top and bottom to dampen the direct shock to the hard drive. Anti-Liquid Splash Material protects your drive from accidental spills and storing your drive in the HDD protection case gives it a dust-free shelter.
- Anti-shock
- Dust-free
- Splash resistant
- Stackable
Was [£5.10] Inc. VAT
Only £4.74 inc VAT.
ORDER NOW
Akasa Dual 2.5" SSD/HDD Mounting Kit @ £5.40 inc VAT
This mounting kit allows you to install two 2.5" SSD/Hard Drives into a standard 3.5” drive bay of a PC case. Introduce new technology high-speed SSD (solid state drives) or make use of laptop HDD in your PC. High-grade aluminium enables rapid heat dissipation.
- 2x 2.5" SSD/HDD Compatible
- 100% aluminium for rapid heat dissipation
- Fits in 3.5" PC bay
Was [£6.12] Inc. VAT
Only £5.40 inc VAT.
ORDER NOW
Intel 8GB USB 2.0 Flash Drive @ £5.99 inc VAT
Intel has always provided the ultimate cost effective mobile storage solution for people on the go. Working on a presentation, a document or e-mails and need to take them with you? No problem! Want to share new MP3 files or digital pictures with your friends? It is really easy! Simply copy the files onto Intel USB Pen and take them with you. To access your data, simply plug Intel USB Pen into any PC or Mac - without the need for software drivers, bulky cables or adapters. Also ideal for downloading films onto for watching on USB compatible TV sets.
- Save, access and share data with colleagues and friends
- Slimline design allows direct placement next to other USB devices
- Easy installation, no drivers needed, USB port bus powered
- Compatible with PC, notebook and Mac allowing cross platform file sharing
- Ideal for storing and sharing digital pictures, music files, text files, spreadsheets & presentations
Was [£9.98] Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Freecom Databar 8GB USB 2.0 Flash Drive (34547) @ £8.39 inc VAT
Freecom DataBar has always provided the ultimate cost effective mobile storage solution for people on the go. Working on a presentation, a document or e-mails and need to take them with you? No problem! Want to share new MP3 files or digital pictures with your friends? It is really easy! Simply copy the files onto DataBar and take them with you. To access your data, simply plug DataBar into any PC or Mac - without the need for software drivers, bulky cables or adapters.
Was [£10.20] Inc. VAT
Only £8.39 inc VAT.
ORDER NOW
Kingston Back To School DataTraveler Generation 2 8GB USB 2.0 Flash Drive (KE-U188G-2AQ) @ £9.68 inc VAT
Impress your teachers, friends and family with the Back to School DataTraveler from Kingston Technology. This USB drive is ideal for every busy and diligent student who needs to store and carry coursework, photos, music and other files. Supplied with a sturdy built in key chain loop, it's easy to attach to your key ring enabling you to carry all your data with you wherever you travel. Supplied with a five-year warranty, 24/7 tech support and legendary Kingston reliability, you will always be top of the class with Kingston.
- Capacity: 8GB
- Convenient - pocket-sized for easy transportability
- Simple - just plug into a USB port
- Practical - no cap to lose; USB connector protected within case
- Dimensions: 58.3mm x 23.6mm x 9.0mm
- Guaranteed - five-year warranty
Only £9.68 inc VAT.
ORDER NOW
Patriot Extreme Performance Xporter Rage 8GB USB Flash Drive @ £14.99 inc VAT
The Patriot Extreme Performance Xporter XT Rage is a USB Flash Drive with both performance and functionality. Featuring a Quad Channel configuration, the Rage improves on traditional USB 2.0 Flash Drives to offer up to 27MB/s read and 25MB/s write transfer speeds. Improved functionality and durability is designed in to the Rage with its rubber coating on the housing and retractable USB connector: the Rage is easier to hold and use, more durable to drops and daily abuse and the connector is protected when not in use. The Patriot Xporter Rage is available in 8GB, 16GB, 32GB and 64GB capacities and carries a lifetime warranty.
- Massive 8GB storage capacity
- 27 MB/s read
- 25 MB/s write
- Durable rubberised finish
- Stylish two-tone casing
- USB 2.0 compatibility
- Lifetime warranty
Only £14.99 inc VAT.
ORDER NOW
Intel 16GB USB 2.0 Flash Drive @ £14.99 inc VAT
Was [£19.99] Inc. VAT
ORDER NOW
Kingston 2GB SD Flash Card (SD/2GB) @ £4.19 inc VAT
Join the many schools, consumers, businesses and government groups that use Kingston's standard Secure Digital cards when using SD-enabled devices. With the built-in write-protection switch to prevent accidental data loss, Kingston's legendary quality assurance and affordable price - you'll get peace of mind and the best price-to-performance value.
- Capacity: 2GB
- Lifetime Warranty
Was [£4.99] Inc. VAT
Only £4.19 inc VAT.
ORDER NOW
Kingston MobileLiteG2 Card Reader (FCR-MLG2) @ £4.55 inc VAT
Kingston’s MobileLiteG2 is a compact, portable, multifunctional card reader that lets you easily transfer digital data, photos, games, music and more stored on memory expansion cards between all kinds of digital devices. Designed for use with different types of SD/SDHC and microSD/SDHC Flash memory cards, MobileLiteG2 lets users carry a single device to store, transfer or read data on any USB host device while using a variety of Flash cards for mobile phones, digital cameras, Netbooks, computers, MP3 players and more. Ideal for personal or professional use, MobileLiteG2 will quickly become an essential part of your mobile gear. It’s ultra-portable, plug and play and requires no external power source. It supports SD/SDHC, microSD/SDHC, MSPD, MS Pro HG Duo and M2.
- Compliant - with the USB 2.0 specification, USB storage Class V1.0, SD 2.00, SDHC 4.1 standards, new MS PRO-HG DUO standard
- Versatile - multi-functional USB card reader supports SD/SDHC, microSD/SDHC, MSPD, MS Pro HG Duo and M2
- Portable - easily fits in your pocket
- Easy - plug and play into any USB 2.0 or 1.1 port
- Guaranteed - two-year warranty on MobileLiteG2
Only £4.55 inc VAT.
ORDER NOW
Interesting.
How does the Kingston MobileLite compare to an internal card reader?
Its actually rather good and to my surprise performs admirably! It uses USB which is the same as an internal unit (these use the usb header on the board) so the performance is no slower. Its also quite small so doesnt take up any space in a laptop bag or a draw making this ideal for those who dont really want and internal reader in their system. The only draw back I can see is that you cant plug in an CF if required which may limit the SLR user.
Smashing, order placed.
Will save me phaffing around with cables or bluetooth!
