**WEEKEND ONLY DEALS ROUND 5: COOLING**
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hey guys
got some tasty deals you might like here.
great prices on market leading products.
this weekend only :cool:
Alpenföhn Matterhorn Pure Edition CPU Cooler (Socket LGA2011/1366/1155/1156/775/ AMD AM3/AM3+/AM2/AM2+/FM1) @ £26.99 inc VAT
What characterizes a good mid-class CPU cooler…Is it a premium-quality finish, a high performance, a low-noise fan or is it the dead easy mounting in nearly every Midi Tower case?
With our brand-new Matterhorn Pure we combine all these points and offer the ultimate high-end package at a nearly unreasonable low-price. The special trapezoid shaped fins that are placed in a 180° rythm creating two essential advantages:
- Narrow Fin pitch in the center of the heatsink: This feature increases the thermal surface and ensures a higher heat dissipation
- Wide fin pitch at air inlet area: By having a wide fin pitch at the air inlet area the Alpenföhn „Matterhorn" can be run with very low fan speed as the airflow faces less resistance.
Despite that the "Matterhorn" cooler has closed sides. This helps guiding the air through the narrow fin area and offers better mechanical stability
Heatsink Spec:
- Size: 138x123x158mm
- Weight: 657gr
Fan Spec:
- Size: 120x120x25mm
- Rated Voltage: 12 VDC
- Speed: 500 - 1500 RPM
- Airflow: 108 m³/h
- Bearing: HD-Bearing
- Auto Restart: Yes
Was £29.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Akasa AK-CC4007EP01 Nero 3 CPU Cooler (Socket LGA775/1155/1156/1366/2011/AMD AM2/AM2+/AM3/FM1) @ £19.99 inc VAT
Akasa NERO classic design combines peak performance and near silent operation. A multi-platform cooler designed for the entire range of current Intel and AMD processors. The four high capacity heatpipes utilize direct CPU contact technology for rapid heat transfer. Direct contact eliminates thermal resistance thereby increasing efficiency. High grade aluminium profiled fins ensure optimum heat dissipation. A piano black 120mm PWM fan is mounted using anti-vibration siliconized rubber pins giving whisper quiet cooling.
The product design has been refined to ensure ultra quiet and exceptional cooling for CPU’s up to 150W TDP (Thermal Design Power). It is compatible with the new forthcoming Intel LGA 2011 processors. Akasa (patented) Easy Select Clip with Intel reference push-pin retention is used for no-hassle mounting on Intel LGA775, LGA1155, LGA1156 and LGA1366 platforms - no backplate is needed. AMD Sockets 939, AM2, AM2+ and AM3 are catered for with a cam-lever clip for safe and easy attachment. Performance thermal compound is supplied.
- Four high capacity 6mm heatpipes with direct CPU contact
- Piano black 12cm fan with PWM
- Siliconized rubber fan mounts for enhance ultra quiet performance
- Cooler dimensions: 120 (W) x 86.7 (D) x 160 (H) mm
- Heatsink material: High grade aluminium fins, copper heatpipes
- Heatpipe: 6mm x 4
- Weight: 609g
- Installation: Push pins (Intel LGA775 / 1155 / 1156 / 1366)
- Screws (Intel LGA2011)
- Cam-lever clip (AMD)
- Fan dimension: 120 x 120 x 25mm
- Fan speed: 500-1500 RPM (PWM controlled)
- Max airflow: 50.54 CFM
- Max air pressure: 1.32 mm H2O
- Noise level: 24.6 dB(A)
- Voltage rating: DC 12V
- Bearing type: Sleeve
- Fan life expectancy: 30,000 hours
- Fan connector: 4pin PWM
Was £23.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
NZXT Havik 120 CPU Cooler (Socket 775/1155/1156/1366/2011/AM2/AM2+/AM3) @ £46.99 inc VAT
To achieve superior CPU cooling, you can count on NZXT’s award-winning HAVIK series to rid of all your heating issues. In comparison to the HAVIK 140, the HAVIK 120 is compact offering more versatility. This 120mm CPU cooler is perfect for overclockers seeking a small yet powerful fan cooler. The base is composed of nickel-plated copper material that utilizes four 8mm pipes for transferring heat to aluminum fins. This allows more air to reach the heatsink which keeps temperatures low while increasing longevity of your components. HAVIK 120 is a victory for any enthusiast looking for an inexpensive and high performing silent CPU cooler.
- Dimensions: 125(W) x 160(H) x 112(D) mm)
- Weight: 980g (with dual 120mm fans)
- Fan Size: Dual 120(W) x 140(H) x 25(D) mm
- Long Life (Oil-Leaking Prevention)
- Fan Speed: 1200 +/- 10% RPM (low); 1500 +/- 10% RPM (high)
- Noise Level: 18-22 dBA
- Air Flow: 61.5-75.8 CFM
- Connector: 3-Pin
- Compatibility: Intel Socket: 2011, 1366, 1155, 1156, 775 / AMD Socket: AM3, AM2+, AM2 CPUs
Was £52.99 Inc. VAT
Only £46.99 inc VAT.
ORDER NOW
Thermalright Silver Arrow SB-E CPU Cooler (Socket LGA 2011/1366/LGA1155/LGA1156/LGA775/AM2/AM3/FM1) @ £59.99 inc VAT
8 X 6mm sintered heat-pipes effectively takes away excessive heat from the CPU when overclocked, Nickel Plated heat-pipes, slower Oxidation and deterioration of the heat-pipes, provides longer period of Thermal conductivity.
Double fin design , each side with 154mm*120mm heat dissipation area, can be used with 14 or 15 cm fan ( fan clips included).
Special Arrow fin design, which allows cool air to pass through and take heat away rapidly, effectively provide cooling for the cpu.
Support Multiple-Platforms. Can be used on Socket 2011/1366/1155/1156/775 Platform, and AM2/AM2+/AM3/AM3+/FM1 Sockets.
Including TY-150&TY-141 Ultra low noise PWM fans and PWM Y-Cable. With the compatibility of up to 3 fans maximum.
• Cooler Dimension: Length 155mm x Width 105mm x Height 165mm (without fans) 170mm x Width 130mm x 170mm (with both TY-141 and TY-150 fan installed)
• Cooler weight: 1124g (including two Fan, without mounting brackets)
• Heat-pipe: 6mm Sintered Heat-pipe*8 units
• Cooler Base Material: C1100 Pure Copper with Nickel Plating.
• TY-150 Length 170mm x Width 26.5mm x Height 150mm
• TY-150 Fan Speed: 500~1100 RPM (PWM)
• TY-150 noise level: 17~21dBA
• Fan Airflow: 38~84CFM
• TY-141 Length 170mm x Width 26.5mm x Height 150mm
• TY-141 Fan Speed: 900~1300 RPM (PWM)
• TY-141 Fan noise level: 21~25dBA
• Fan Airflow: 28-74CFM
Was £69.98 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Thermalright True Spirit 140 CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA775/AM2/AM3) @ £31.94 inc VAT
Ultra style heatsink fin array, with copper base, elevates heatsink’s overall quality. Large heatsink fin array, provides dissipating area of up to 150*125mm, make complete use of the airflow, with 140mm or 120mm fan. With the max width of 55mm, tall memory spreaders are no issue. The cooler is supplied with one Thermalright TY-140 PWM fan, ultra low noise at 21 dBA at max rpm (50cm testing distance)
Fan-clips are compatible with both 140mm and 120mm fan.
Heatsink Specifications:
- Dimension: Length 155mm x Width 53mm x Height 170mm
- Weight: 771g (including fan and pads. excluding mounting brackets)
- Heatpipe: 6mm heatpipe*6 units
- Copper Base: C1100 Pure copper nickel plated with mirror shine
Fan Specification:
- Dimension: L160mm x H140mm x W26.5mm
- Weight: 140g
- Fan speed: 900~1300RPM (PWM controlled)
- Fan noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Fan connector)
Was £39.95 Inc. VAT
Only £31.94 inc VAT.
ORDER NOW
Arctic F12 PWM Case Fan - 120mm @ £3.98 inc VAT
The ARCTIC F PWM forward the PWM signal from the CPU to the whole case ventilation system. The entire system is cooled quietly, but still offers the superb performance when needed.
Dimensions F12: 120 mm
Fan Speed F12: 600 - 1350 RPM
Air Flow F12: 74 CFM / 125.1 m3/h
Bearing: Fluid Dynamic Bearing
Noise Level F12: 0.3 Sone
Net Weight F12: 107 g
Limited Warranty: 6 years
Was £4.39 Inc. VAT
Only £3.98 inc VAT.
ORDER NOW
Alpenföhn 120mm Wing Boost Plus PWM Fan - Black & White @ £9.98 inc VAT
Near silent 12 cm fan with distinctive Black coloured rotor blades and Black & White frame. Designed with low air impedance blades, providing the ultra quiet acoustic experience.
- Dim: 120 x 120 x 25mm
- Rated speed: 1500 RPM
- Sound: 21.0 dB(A)
- Air flow: 61 CFM
- Bearing: Sleeve Bearing
- Life expentancy: 30,000/ hrs
Was £13.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Prolimatech Red Vortex Red Wings Red LED 120mm Fan @ £8.99 inc VAT
Specifically designed to work with Prolimatech Armageddon/Megahalems/Super Mega for best performance to noise ratio. Stable bearing for long life operation at minimal noise level. Quality material used in fan blades for a solid structure design.
- Dimension: (L)120mm X (W)120mmX (H)25mm
- Bearing Type: Sleeve bearing
- Operating Voltage Range: 7~13.8 VDC
- Rated Current: 0.2 Max.Amp
- Rated Power: 2.4 Max.Watt
- Rated Speed: 1000±100RPM
- Airflow: 87 Max.CFM
- Noise Level: 18.1 dBA
- Net Weight: 162 Gram
- Connector: Terminal Connector(3-pin plus 4-pin molex)
Was £10.99 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin @ £11.98 inc VAT
The GentleTyphoon achieves high airflow volume and low noise with the newly designed impeller, enabling silent cooling of the latest devices which run very hot.
The GentleTyphoon has a different type of tone. The fan propeller is designed to reduce the disturbing frequency fan noise to human ears. The newly designed motor and motor support mechanism of the GentleTyphoon uses a double vibration reduction structure. The new support mechanism uses coil dampers to greatly reduce vibration.
- Manufacturered in Japan
- Only 21.0 dB(A) at 1850 RPM
- Weight 200 g
- Dimensions 119 x 119 x 25 mm
- Air volume at full speed (12V), CFM ±10% 58.0
- Noise level at full speed (12V), dB(A) 28.0
- Fan speed at full speed (12V), RPM ±10% 1850
- Bearing Type Double Ball Bearing
- MTBF 100,000 hour at 35°C or 60,000 hours at 60°C
- Accessories 4-pin Molex Adapter, 4x Screws
Was £14.98 Inc. VAT
Only £11.98 inc VAT.
ORDER NOW
The Thermalright Silver Arrow SB-E wont fit on a Asus Rampage IV Extreme will it? (Well not without blocking the top PCI-e slot.)
The Thermalright Silver Arrow does, just, by millimetres. My understand is the SB-E version and fans are wider (or taller or longer depending on how you look at it)?
i have gone a bit loopy on some of them, take advantage before i come in on monday in a big mood and put the pricing back to how it was!
do you sell cables or a cable which will combine 4 GT AP15's into one channel on the Lamptron FC5V2?
Additionally what rubber mounts will allow them to fit onto the side of the corsair 650d with a side mesh panel?
If you stock the above then I'll place an order ;)
Cheers,
Majnu these should work fine for you. http://www.overclockers.co.uk/showproduct.php?prodid=CB-013-AK&groupid=1929&catid=153&subcat= If you buy afew and link them or if not have a look at these. http://www.overclockers.co.uk/showproduct.php?prodid=CM-096-BX
Ide go for the bitfenix but i just bought some of the others as im on a budget. If you combine both you will get the 4 off 1 channel. Check your controller will output enough per channel to power them though
lamptron is a beast, iirc it can take 6 gt ap15's on one channel.
Thanks for the links I'll check them out.
any dBA details for the Arctic F12? How would it compare to a Akasa Apache black?
Build quality on the Apache Black is much better than the Arctic F12s, if it was me I'd get/keep the Apache Blacks, you get what you pay for.
With regards to CFM and dBA, with the RPM reduced on the F12 they are similar to the Apache in noise and airflow. However the advantage with the Apache Black is it is PWM, I also found them smoother in tone.
Scythe Gentle Typhoons are great fans for Radiators they have great static pressure and really pull the air right through in push / pull configuration. Will be ordering more of them.
Cooler arrived today.
Fantastic service from OcUK, ordered on Saturday arrived this morning. Hopefully fitting it tomorrow.
Order date and time: 7 Jul, 12, 11:24 am.
Your parcel has been delivered, on 09 Jul 2012 at 11:38
Many thanks.
