**WEEKEND ONLY DEALS ROUND 6: SOLID STATE HARD DRIVES!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some great deals on SSD's here for you guys:-
Mach Xtreme Technology 60GB 2.5" SATA 6GB/s MX-DS TURBO PREMIUM Edition SSD @ £59.99 inc VAT
The MX-DS TURBO PREMIUM Edition Series offers mobile and desktop users groundbreaking computing experience and unparalleled level of read and write performance. The PREMIUM Edition is fine-tuned for IOPS performance. This series of SSDs delivers performance that maximizes the throughput of a SATA III 6Gb/s interface with balanced read/write speeds.
This series supports DuraClass™ and DuraWrite™ technologies. DuraClass™ technology provides best-in-class endurance, performance, and low power consumption. DuraWrite™ technology optimizes writes to the flash memory over conventional controllers increasing the overall endurance and reliability of the complete SSD. Highly intelligent block management and wear leveling also extends the overall endurance.
- NAND Flash: MLC
- Capacity: 60GB
- Interface Type: SATA III
- Form Factor: 2.5"
- Dimension: 99.8 x 69.63 x 9.3 mm (LxWxH)
- Lightweight: 80g
- Max. Read Performance: Up to 540MB/s*
- Max. Write Performance: Up to 490MB/s*
- IOPS: up to 60,000
- Warranty: 3 Years
Was [£65.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Sandisk Ultra SSD 60GB 2.5" SATA-2 Solid State Hard Drive - (SDSSDH-060G-G25) @ £41.99 inc VAT
Upgrade your laptop to high-performance and extend its battery life with the reliable SanDisk Ultra® SSD. You’ll enjoy faster boot-ups and shutdown in up to half the time compared to a 7200 RPM hard drive§. The SanDisk Ultra SSD is backed by rigorous shock and vibration testing and a 3-year limited warranty†. The SanDisk SSD features no moving parts, quiet operation, and low power consumption as compared to a 7200 RPM hard drive.
- SandForce SF-1200 Controller
- Upto 280MB/sec Read performance
- Upto 270MB/sec Write performance
- SATA-II (3Gb/s) (Compatible with all SATA versions)
- Operating temperature: 0c to 60c
- Power Active: 0.43W
- Shock Resistant: 1500G @ 0.5 msec
- Vibration: 2.17gRMS, 5-700Hz
- Delivers reliability, durability, and performance for your laptop or desktop
- Faster system boot up and shutdown .the rugged SanDisk Ultra SSD can boot up or shut down your system up to twice as fast as compared to a 7200 RPM HDD˜
- Speedy read and write performance.up to 280 MB/secö read and up to 270 MB/secö write performance Designed for high durability.engineered to withstand shocks and vibration
- Long-term endurance - the 60 GB SanDisk Ultra SSD can withstand at least 40 terabytes* of data written to it over lifetimeĢ, while the 120 GB and 240 GB drives can withstand at least 80 terabytes and 120 terabytes of data written, respectively
- Lower power consumption - as compared to a standard 7200 RPM Hard Disk Drive
- Noise reduction - the SanDisk Ultra SSD provides quiet drive operation
- 3y Warranty
Was [£49.99] Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Intel 330 Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail @ £65.99 inc VAT
Get Fast. Play Fierce.
Faster game and application loads, less lag, smoother visuals.
Stay ahead of the competition when you level up to 6.0 gigabits per second (Gb/s) performance
New Level of Performance
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 500MB/sec
- Maximum Write: 450MB/sec
- Max I/O Per Second (IOPS): 33000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 years
Was [£71.99] Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
OCZ Agility 3 240GB 2.5" SATA 6Gb/s Solid State Hard Drive (AGT3-25SAT3-240G) @ £129.95 inc VAT
nonl2brAs the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
<br><br>
- Capacity: 240GB<br>
- Controller: SandForce SF-2281<br>
- Maximum Read: 525MB/sec<br>
- Maximum Write: 500MB/sec<br>
- Max I/O Per Second (IOPS): 85,000 IOPS (4KB File)<br>
- NAND Flash: Multi-Level Cell (MLC)<br>
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)<br>
- TRIM Support (Requires Windows 7)<br>
- Winner of 54 awards/reviews worldwide<br>
- Warranty: 3 Years<br>
<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/rF5PdfFGomw" frameborder="0" allowfullscreen></iframe>
Was [£139.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA 6Gb/s Solid State Hard Drive (VTX3-25SAT3-120G) @ £89.99 inc VAT
nonl2brAs the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.<br>
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br>
<br>
- Capacity: 120GB<br>
- Maximum Read: 550MB/sec<br>
- Sustained Write: 500MB/sec<br>
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)<br>
- 2.5" to 3.5" SSD adaptor included<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/CKMODN3kIpE" frameborder="0" allowfullscreen></iframe>
Was [£109.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Don't miss out and grab yourself an SSD this weekend. :D
Nearly brought this at 3pm but got side tracked watching the tennis. Glad I waited now :D
Also entering the SSD world for the first time.
Not buying anything till I see the crucial m4 128GB or the Samsung 830 one at £65!!!! ;) :p
Do not mention competitor prices still very competitive). They may drop further, but I doubt it will be by much - certainly not compared to the recent price crashes. And with NAND/DDR, prices can go up quite suddenly too.
The reasons/rumours I've heard for the current price drops are :
- Shifting "old" stock ready for next-gen SSDs/controllers (Sata4 ?)
- A global glut of NAND chips
- The big boys (Samsung, Crucial, OCZ) forcing out the numerous small players ***
*** Although I'm all for healthy competition, there do seem to be endless Sandforce clone drives, which offer nothing new except a different coloured case. Basically, we need less SSD manufacturers and more for HDDs.
Indeed!
£75+ is more than what I would like to spend really, very tight budget :o :p
I think ocuk had the m4 128GB at about £65-70 for a one day only deal a few months ago, so I am patiently waiting for that again or one for the Samsung 830 series SSD :p
Also crucial are supposedly releasing their new SSD sometime soon (which is why there have been quite a lot of deals on their current ones recently)
I can't see them dropping by too much either over the next few months :( But I am hoping OCUK will have a "today only" deal for one or both of them at some point :p
Loving the price on the Agility 3.
Ordered :) Entering the SSD world for the first time.
You're going to love it.
I paid £180 for my 120GB vertex2e, so £130 for that 240GB Agility 3 is looking mighty tasty. I might have to shift all my big progs (photoshop etc) onto one of them. Hmmmmmmm. Hmmmmmmmmmmmmmmmmmm.... If only I hadn't just put down a deposit on a flat.... I could live in a box maybe.
@ Bulldog147 While I certainly dont have the money for such a thing, Its not actually that expensive. Crazy when i think my sata2 128gig M225 cost me £320 when i got it...
Thankfully it died and i got an M4 as a warranty replacement :p
@Devrij Same boat here, deposit and 3 months advanced rent... what a killer. On the positive the new flat is kickass :)
Yeah it quite scary when one of the SSD had died on us, not a nice pleasure feeling as we don't believe a wording MTBF of a million of hours. I heard that the only SSD that never died is Intel, M4!
yeh well thankfully crucial had a 5 year warranty on my drive. and were very quick and easy to deal with. and a huge 2 generation leap in upgrades :D yay for crucial.
