WEEKEND ONLY DEALS - ROUND 9 POWER SUPPLIES!!!!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair Professional Series™ Gold AX1200 High Performance 1200W Power Supply (CMPSU-1200AXUK) @ £214.99 inc VAT
The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you. All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it’s time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling — the cables stay in place and connect to your new fully-modular Corsair power supply. With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It’s earned the 80 Plus® Gold seal of approval, your guarantee that you’re making the right choice for smart, efficient power delivery.
- Supports the latest ATX12V v2.31 and EPS 2.92 standards and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80 Plus Gold certified to deliver at least 90% efficiency at 50% load
- Active Power Factor Correction (PFC) with PF value of 0.99
- A dedicated single +12V rail offers maximum compatibility with the latest components
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
- High-quality Japanese capacitors provide uncompromised performance and reliability
- Completely modular cable system allows you to use only the cables you need
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis
- A seven year warranty and lifetime access to Corsair’s legendary technical support and customer service
- Dimensions: 150mm(W) x 86mm(H) x 200mm(L)
- MTBF: 100,000 hours
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
- Seven Year Warranty
Was £226.99 Inc. VAT
Only £214.99 inc VAT.
ORDER NOW
Adata HM 850W Modular Power Supply @ £104.99 inc VAT
Choosing the right power supply affects the lifespan and reliability of your computer. ADATA’s HM Series should be at the top of your list. Certified by 80 Plus Bronze to achieve 82% sustained power, the HM Series provides continuous power in a full range of wattages and includes high-quality 100% Japanese made capacitors. Better yet, the HM Series equips modularized cable management and an intelligent dual ball bearing tri-color LED fan that reduces resonance of the fan axis, resulting in high airflow cooling, and also keeps you informed of your computer’s power status. ADATA HM Series power supplies are the one that delivers you high-efficient performance and ultimate reliability in the market.
ADATA HM Series power supplies deliver superior performance, reliability and protection for all types and levels of applications. In particular, the HM Series equips an intelligent dual ball bearing LED fan with a tri-color output power display for easy access to power consumption stats (green for low load; blue for normal load; red for full load.
ADATA HM Series power supplies feature a smart modularized cable management that allows you to adjust cables according to the number of devices flexibly, reduces unused cable clutter and improves internal airflow for high-efficient heat dissipation within the case. To achieve ultimate gaming performance, In addition, it is compliant with ATX 12V v2.2 and v2.3 and EPS 12V v2.92 to support various system configurations and chassis.
- 3 Colour intelligent dual ball bearing LED fan with a tri-colour output power display for easy access to power consumption stats (Green / Blue / Red)
- Efficiency up to 85% at typical load
- All long-life & low ESR japan made capacitors
- Flexible detachable cable
- Active Power Factor Correction with PF value of 0.9 to ensure reliability and clean power
- OCP,OVP,SCP,OPP,UVP,OTP ready
- PCI-E 6Pin ready for high-end VGA cards
- New circuit for high efficiency & high watt design
- Special Scratch Resistant Paint
- 3 Year Warranty
Was £119.99 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
OcUK Crusade 650W Dual-Rail High Efficiency Power Supply @ £42.98 inc VAT
This 650W PSU is designed for entry level systems that require a lot of power. With 2 dedicated 12v rails this Power Supply ensures that power can be perfectly spread throughout your systems without any overloading while the massive 120mm silent fan helps keep the system cool.
- High Efficiency
- Auto Switch
- Multi-GPU support: independent double +12V rails designed specially for dual graphic cards
- Active PFC: enhances utilization of energy
- Ventilation: 1 x 12cm fan
- Full range: AC full range input
- Fan Speed Control
- Energy Star
- Short Circuit Protection
- Over Voltage Protection
- 1 x 20+4 motherboard connector
- 1 x 4pin CPU connector
- 4 x SATA connectors
- 4 x Molex connectors
- 2 x 6Pin PCIe connectors
- 1 x Floppy drive connector
Was £47.99 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
Cooler Master GX 750W Power Supply @ £60.98 inc VAT
The latest addition from Cooler Master is a range of power supplies that specifically targets the upper mid-range to high-end gaming systems, the Coolermaster GX Series. The Coolermaster GX range of power supplies feature a single powerful +12V rail that has been designed to delivery more than ample power to dual graphics card systems, no matter if you use SLI or CrossFireX.
- Compliance with the latest Intel standard ATX 12V
- Single +12V rail for the most demanding SLI configuration
- High effciency design that meets 80 Plus requirements (85% typical)
- Ultra-silent operation with intelligent 120mm fan speed control
- Multipe protection design (OVP/ UVP / OPP / OTP / SCP)
- High reliability (MTBF > 100,000)
- Double Layer EMI Filter restrains noise and injury to end-user
- Huge bulk capacitor for hold up time > 17ms at full load
- Integrating Active PFC with PWM combo controller not only make PFC higher than 0.99, but also raises efficiency
- Efficent transformer for reducing 5Bsb power loss when the system is at turn-off and sleep modes
- Five Year Warranty
Was £64.99 Inc. VAT
Only £60.98 inc VAT.
ORDER NOW
BeQuiet Pure Power L7 530W Power Supply @ £46.99 inc VAT
Need a power supply that will smooth your path onto the web, securely and reliably? A unit that will handle standard office and graphic programs without a problem, and is always ready for a little gaming here and there as well?
If so, then PURE POWER is the right choice for everything you'll need from your computer – stabile, cost-saving operation (80PLUS). And because the be quiet! name is behind these units, you'll probably barely even realise they're there. Efficiency and reliability was never more affordable!
- Classic office and web applications
- Standard graphics applications
- Basic gaming
- 120 mm quality fan.
- The RPMs on the fan are automatically governed based on the temperature
- 80PLUS certification. The high efficiency of up to 87% reduces power dissipation (waste heat) and also saves power.
- Fulfils the requirements of the environmental and energy-savings Energy Star 4.0 * guidelines
- Low power consumption in stand-by mode (<0.5 W).
- Fulfils the EuP guidelines
- Various connection options, with up to 15 connectors
- 2 years manufacturer's guarantee
Was £49.99 Inc. VAT
Only £46.99 inc VAT.
ORDER NOW
Adata are mainly known for RAM manufacturing, but they have released the psus.
They are OEM built by CWT - the same people who make the HX range for Corsair.
Does that mean they are as good as the corsair HX range or just built as well but possibly designed worse?
I was really hoping for a good deal on the HX1000 which is already £15 more expensive than at least one competitors prices!
While i'm in a PSU thread, what are the Cooler Master Silent Pro M and Gold PSUs like compared to the Corsairs and Antecs?
