Hi chaps and chapettes
I've resisted the urge (for now) to buy a new case (DD DW *21*) so I can get my GPU under water as well as the motherboard...
Now I WAS going to drain, flush, clean the old blue X1 and move over to an orange coolant, but I simply can't be bothered, so I'm going to use coloured tubing.
Tubing needs to be orange, I'm torn between the XSPC stuff that states its Red/Orange UV but actually looks Orange or the Masterkleer stuff that simply states UV Orange, again it looks orange to me. Never used Masterkleer and a big fan of XSPC, so does the below look orange enough to you guys?
Second question, I want to move over from my current silver Bitspower fittings to something black (feel it will contrast better), I like the look of the below Koolance fittings, though listed in the 7/16 - 5/8 section they state 1/2 - 5/8. Now I know that 7/16 ID will fit over the 1/2 ID and that the OD is the same on both tubing and compressions, anyone confirm 100% that these work?
YOUR BASKET
2 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Red/UV Orange £5.98 (£11.96)
10 x Koolance Nozzle Single, *Black* Compression for 13mm x 16mm (1/2in x 5/8in) £3.98 (£39.80)
4 x EK-PSC Adapter Rotary 45° G1/4 Black £3.59 (£14.36)
4 x EK-PSC Adapter Rotary 90° G1/4 Black £3.59 (£14.36)
Total : £91.00 (includes shipping : £8.75).
YOUR BASKET
