- 11 Dec 2005
- Cheshire
Now time for even more sweet deals
two overclocked bundles and an ultra small Foxconn Mini PC barebones! Get these whilst they last as these are some damn hot prices!
"Krypton Z77 690i" Intel Core i7 3770K 3.50GHz @ 4.50GHz DDR3 Ivybridge Overclocked Bundle @ £599.98 inc VAT
Designed by experts the "Krypton Z77 690i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.50GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z77 690i" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.50GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- Quad Core overclocked CPU with Hyper threading
- 16GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s and Intel Ethernet for next gen computing
Bundle Specification
- CPU: Intel Core i7 3770K 3.50GHz @ 4.50GHz Ivybridge CPU
- Motherboard: Asus P8Z77-V Intel Z77 (Socket 1155) DDR3 Motherboard
- RAM: Corsair Dominator 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel
- Cooler: Prolimatech Megahalem CPU Cooler w/ x2 Tech Labs Zaward 2000RPM 120mm Fan
- Artic Silver 5 Thermal Compound
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £639.98 Inc. VAT
Only £599.98 inc VAT.
ORDER NOW
Krypton Crosshair 850a AMD Bulldozer FX-8 8120 3.10Ghz @ 4.00GHz Overclocked Bundle @ £403.99 inc VAT
Designed by experts the "Krypton Crosshair 850a Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Krypton Crosshair 850a Bundle" will accelerate your computer experience into the next level.
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- Eight Core processing performance
- CPU: AMD Bulldozer FX-8 Eight Core 8120 Black Edition 3.10Ghz @ 4.00GHz
- Motherboard: Asus Crosshair V Formula AMD 990FX (Socket AM3+) DDR3 Motherboard
- RAM: Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Corsair A50 CPU Cooler
Service Package
Was £433.99 Inc. VAT
Only £403.99 inc VAT.
ORDER NOW
Foxconn nT-A3550 AMD E350 Chipset DDR3 Nettop Barebones @ £149.98 inc VAT
Small and exquisite shape brings you the enjoyment of the beauty , whilst enabling you enjoy the life with speed and share worldwide splendidness, is the best choice of being placed at home or office.
- Series: Brazos
- Dimension: 190(W) x 135(D) x 24(H)mm
- Processors Supported: AMD E350 Zacate Dual core 1.6GHz
- Chipset: AMD A45 FCH
- Memory Supported: DDR3 1066MHz
- VGA Graphics: AMD Radeon HD 6310
- Storage Interface: 1x 2.5" SATA II 3Gb/s
- LAN: IEEE 802.11b/g/n
- Front I/O:
1x SD/SDHC/MS/MS Pro/MMC 5 in 1 Card Reader
2x USB 3.0
1x Mic in (support S/PDIF-IN)
1x Headphone
- Back I/O:
1x RJ-45 (10Base-T/100Base-T/1000Base-T)
4x USB 2.0
1x Line-out jack.(support S/PDIF-OUT)
1x HDMI
1x DVI
1x DC in
Was £169.99 Inc. VAT
Only £149.98 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
- Series: Brazos
- Front I/O:
2x USB 3.0
1x Headphone
- Back I/O:
4x USB 2.0
1x HDMI
1x DVI
1x DC in
ORDER NOW
