RE: https://www.overclockers.co.uk/msi-...40hz-0.03ms-gaming-monitor-mon-msi-04381.html
Looking to replace a couple of stand mounted 27" IPS panels with two of these. Are OLED screens typically heavier? My desk edge has a chamfered edge so I use a free standing mount which has max weight on each mount point of 8kg, the weight doesn't seem to be listed on the specs either on the OCUK product page or the MSI page, any clue as to the weight of these things?
Also, looking to use 2x TB 5 output from my Mac dock for the USB-C DP Alt connector but never used this type of connectivity:
Any recommendation for cables?
What sort of refresh rate can DP over USB-C get? (though probably limited from the dock though right?)
Will using USB-C DP Alt conflict with using the full DP 2.1 ports from PC GPU?
