Weird 3d mark basic results between a 570 and a 560ti
24 Oct 2005
North East
Hey all.
I was wondering where you think the problem is because my mates 560ti is beating my 570 gainward phantom card and i just dont like that lol.
His core and mem are clocked a little higher than mine but i wouldnt have thought it would do that much to the test results.
My result
http://www.3dmark.com/3dm/790325?
http://gpuz.techpowerup.com/13/06/16/3h4.png
Mates result with the 560ti
http://www.3dmark.com/3dm/790213
http://gpuz.techpowerup.com/13/06/16/gkb.png
Im running 314.22 drivers he says hes running the same even tho 3d mark says otherwise.
Looks like the physics score is killing ya 570 score, that CPU ya used on that rig must handle physics better i guess.
You should look at the graphics score where you can see, the you score higher.
You're mate is using a Core i7 950 and although it's an older CPU it has hyperthreading and 3Dmark11/13 loves hyperthreading in the CPU tests, so that is why he scores much higher than you in that test and that has effect on the overall result.
