- 16 May 2008
- Bristol
I've applied an undervolt to my 5800X3D by setting a -0.15 VCCDR offset in the BIOS.
This caused the system to refuse to boot, so I removed 1 stick of RAM and it booted, the CPU idle temperature is much improved at around 40c.
I put the stick back in and now it boots ok, but the idle temperature has risen to around 55c!
I've repeated the process 3 times with slightly different VCCDR values, but every time the temperature is dramatically higher with the 4th stick of RAM installed.
Has anyone else seen this behaviour before?
Motherboard: ROG Strix X570-F Gaming
Memory: 2x32GB (CMH64GX4M2D3600C18) + 2x16GB (KHX3200C16D4/16GX)
Cooler: Noctua NH-D15
