weird BSOD
18 Aug 2013
Hi
I've had an asus rog strix 3070 running brilliantly since june '21, not had a problem at all. I even tested an overclock when I first had it that was 3Dmark stable but crashed some games, so its been running stock since then as I didn't feel qualified to mess with it. This morning started up, played trackmania for a bit, was fine. Switched PC off for a while. Started up about an hour after and was getting artefacting even using discord. Thought it might be a problem with the program. So I started trackmania up again to test, it didn't even make it to the main menu before it BSOD'd, a video scheduler internal error. I was shocked since it had started artefacting with next to no load and temperature was fine. So after a while I started the PC up again, going through process of elimination, ended up doing a 3Dmark firestrike extreme run which I understand would stop running if there was a problem, and it ran all the way through with a graphics score of 16838 which is about as good as I ever get. Should I be worried or not? might have been some update shenanigans that needed a restart or something?
Hello, the last time I got a video scheduler internal error I uninstalled and reinstalled the latest Nvidia drivers and everything was fine after that. I also recommend doing a chkdsk via command prompt (run as admin) on your C: drive just to make sure you haven't damaged the file system after a BSOD.
