weird fan speeds
4 Nov 2006
hi guys,
I noticed my CPU temp was higher than normal so took a look at speed fan,
It said my artic freezer 7 pro was running at 406 RPM, its ment to be 900 to 2500RPM, After a reboot the fan speed returned to 2500 and stayed there,
Any one else had this problem? can't work out what Made it slow down.
MB P5W DH
Bios fan setting's all to performance
If you have the Automatic Fan Speed box ticked in speedfan, that may have caused it. Either that or speedfan was reporting the speed wrong.
The Speedfan auto box was not ticked and I think it was reporting the correct speed as the cpu temp was 46C on idle, After the reboot and the fan returning to 2500rpm the CPu temp was 22c at idle. Something else must have turned the speed down?
Cool and quite is off in the bios and all other fan settings are set to performance so the fans should be at full speed.
I am going to run the same programmes I had on yesturday to see if it does it again. :confused:
Speed fan configs... what one should I use..loads on the web site
thanks
