Weird firefox issue
Bry
Bry
24 Jul 2005
Hi guys i got a fairly weird issue with firefox and afaik it only affects overclockers.co.uk site :(
The site loads fine but when i go into any of the sub categories the page just fails to load, it doesnt time out or anything just sits there loading. After about 5 minutes the page loaded is just blank
If i should open a new tab and go to the main page this also occurs. However, once the page stops loading the main page loads fine again.
The sub category problem seems to fix it self by refreshing the page only when it has failed to load (refreshing while it is still loading does not work)
The forums always load fine and so does every other site.
Any idea what could be wrong?
Not a solution, but posisbly a similar problem. I often get it where I click on somehting on the forums and it loads a blank page (instantly, not with a delay like yours). IT says done at the bottem, but its just a blank page. If i hit refresh it loads fine...
Is it the same with IE? I used to have an issue with Windows Firewall blocking the shop, but it doesn't happen every time.
open firefox with
Code:
%programfiles%\mozilla\firefox\firefox -profilemanager
(I think that's the correct path!)
Create a new profile and try it with that. If the problem doesn't occur - bin the old profile.
In what sense? If you edit one of your existing Firefox shortcuts, and add -P to the end of the path, you should get the profile manager.
Edit: In fact, here's a guide.
