weird flicker on bran new monitor
16 Sep 2005
What used to be a UK
As above but the flicker only occurs twice when booting into vista 64.
System spec: q6600, 4 gig ram, ds3r, 8800gt. Monitor HPw2408h. Any ideas? Thanks
Oh, forgot to mention I am using a dvi to hdmi connector.
It just flickers once or twice almost as if you knock a lead but it is so fast I cannot really describe it. I'll just do a reboot and have a good look and see if I can describe it a bit better :)
Here goes:The flicker (which is the screen going momentarily black for half a second, once or twice) only occurs after adding or logging on my password in vista. Prior to this and after it is fine. Wonder if it is a Vista anomaly or graphic card? I haven't checked to see if it does it in xp. .
Just checked, only happens in Vista not xp. Have bumped this to see if anybody has anything to add? :)
