Weird Graphics Card Problems
19 Jan 2005
Cambridge
I’ve been having this weird problem with my Radeon 2900XT for the past month or so. Most of the time it will be fine, but sometimes I get freezing and occasionally blue and white lines on the screen that appear and disappear. After a few seconds the screen will go black then everything will return to normal with a message saying the display driver stopped responding.
Once in a game it’s usually OK, if it’s going to go wrong it’s usually in the game menus. I also get the freezing and display drivers not responding when watching videos.
Once it got really bad and the whole screen went blue and white: http://img214.imageshack.us/img214/2030/image019dc.jpg
Also just today it’s started a new thing where as soon as I start a game the fan starts going at full speed for 3-4 seconds, then normal speed for 2 seconds, over and over on a loop. And I get occasional semi-transparent horizontal lines appearing 1 at a time randomly for just a second.
My first thoughts were that this was drivers, I do upgrade to new driver versions regularly but I’m not sure if I installed a new version around the time this started happening. Anyway I tried going back to a version from last September and still have the problem. The card is definitely not overheating as I have been keeping an eye on the temps.
can you check the events on the control panel, look in particular under windows codes and see if their is an error code 10. I had a similar problem with this and it was due t the graphics card not getting enough power from the PSU, it also caused my fan to stop start and froze the screen on several occasions. you may need to upgrade your PSU.
If you see any other error codes look 0on the microsoft website and it will explain what has caused the problem.
