A tale of woe.........
Bought a Gigabyte GTX460OC 1GB from overclockers about a month ago.
Removed my old HD4850 from the motherboard (Gigabyte Ma790x ud3p) and installed the Gtx460. Installed Nvidia drivers and went about testing the new card. Every time I put the gfx card under load, the screen would freeze within seconds/minutes. Did a clean install of windows on a spare drive, tested again, same problem. Overclockers told me to return it, but I decided to take it to a friend`s house for a final test. It ran fine. Tried it at another friend`s house, again it ran perfectly.
What followed was a lot of component swapping, CPU, RAM etc. Still the problem persisted. I had pretty well pinned it down to the motherboard, so I ordered a cheap Gigabyte motherboard board as a final test, and to use while the UD3p was being fixed. Sure enough, the replacement MB worked perfectly with my new gfx card. So I waited a couple of weeks for Gigabyte to test the returned MB. It arrived back here a couple of days ago "no fault found", they were even kind enough to email me several photos to show my board being tested. I reinstalled the motherboard, and the problem returned. I did another clean install of Win 7, and borrowed a PSU from a friend (just to make sure). I still got lockups after a minute or two of benchmarking. I have never seen GPU temperatures much above 60 degrees (and the system will sometimes freeze before the GPU reaches 40 degrees).
So it seems that the GTX460 that I bought doesn`t work with the motherboard I bought about 12 months ago. The motherboard will work with any other graphics card (even another GTX460), and my GTX460 will work in all the other motherboards I`ve tried it with.
Both my motherboard and gfx card are on their way to be tested together. If Gigabyte tell me there is no problem, I`ll eat my monitor (raw). (Maybe
