- 6 Jan 2006
Hi all,
I hope you can help me diagnose my slightly borked pc. The screen display dies after booting Windows 10 - just after the spinning circles load screen and just before the lock screen initialises. It's almost as if basic VGA graphics work fine but high res graphic kill the display output. Initially I thought it was a corrupt profile or Windows system file issue but it turns out that if I boot the PC with on-board graphics only, it works fine. I've also tried re-installing Windows.
But, it isn't the GTX 970 graphics card either I don't think. Why? Because I've tried the graphics card in both PCIE slots, and also tried my old GTX 570 which did the same thing. So, is it motherboard, or PSU or something else?
Things I could try next - put the GTX 970 in my wife's PC and see if it works (I think it will). Put an old Seasonic 500w PSU into my PC and see if it loads Windows with the graphics card installed (a bit fiddly but do-able).
Am I going along the right lines here or should be I pointing the finger of suspicion at something else?
Thanks for any advice!
Spec:
Intel 3570k overclocked
P8Z77-V PRO
16Gb RAM Corsair Vengence DDR3 (2 sticks)
MSI GTX 970
Antec TruPower 650w PSU
Crucial SSD
Spec:
P8Z77-V PRO
MSI GTX 970
Crucial SSD
