Weird Humming Noise?
12 Nov 2008
T.O.
hey guys,
Im getting a weird humming noise coming from the pc?
its like it builds up then stops, builds up then stops etc.
its not loud but it noticeable and annoying!
The worst part is ive no idea which component is causing it!
v difficult to isolate
any ideas what this could be or is this fairly normal??
thanks again!
:D
hmm hadn't thought about that! ill give that a try tomorrow when fitting new graphics card! thanks!!
merry Christmas btw :D
The noise is coming from my PSU!
hard drives are fine..
what sort of noise is normal cos this is getting louder, surely im entitled to a replacement? Its not acceptable, its louder than my case fans and there is 6 of them!!
nah, im not so sure, i know the noise the F1 makes its like a clicking noise, this is a pulsing wooshing noise from a fan?? having stuck my head in its definitely the PSU area
Shove a pencil in to stop the PSU fan (carefully) and see if the noise disappears. If so, that's the culprit. Possible to change the fan mounts or the whole fan if you don't want to go down the RMA route. Might simply be out of balance due to crap/dust on the blades?
