Hi guys,
I suspect the GPU is faulty, but just want to make sure I'm not missing anything!
I have two Sapphire R9 390 Nitro OC 8GB's in Crossfire.
With both GPU's installed, both show up in the OS and in the AMD software, both are capable of compute tasks too, the system performs roughly twice as well with two cards installed vs. one (mining, rendering, folding, etc)
When installed individually, one works perfectly, but the other only has a display output up to the Windows loading screen, then when the login splash-screen should appear, the screen goes black and the display turns off.
Put the first one in again, and its back to being fine. Cards are identical as far as I know, but is there any chance its an issue with the driver version vs the BIOS version on the card, or is it definitely faulty?
Just seems odd.
TIA. <33
Just seems odd.
TIA. <33
