- 23 Apr 2024
- London
Hi all,
I built a hardline watercooled PC about 15 months ago. Specs were: Lian Li Evo XL; Ryzen 7800X3D; Motherboard: Gigabyte B650E Aorus X Ice; Asus TUF GTX 4080 Super; PSU: Lian Li Edge 1300 PSU; memory: TeamGroup Delta RGB 32GB (2X16); two M.2 drives. Various EK and Alphacool blocks and fittings.
All was working fine until about a week ago. Suddenly, after a crash, I started getting disk errors on both M.2 drives. Windows tried to autorepair but failed every time. Chkdsk found failed sectors and said it repaired them. I tried to reinstall Windows a few times, and got it working again, but then it would find more disk errors. Reconnecting the non-boot drive caused the whole system to stop working again. Weirdly, I started getting intermittent ethernet connection issues at the same time, where it would have to keep reconnecting to the router every minute or so - no other device connected to the router had any issues.
After a few days, it's now got to the point where it now can't see any M.2 drive in either of the slots I'm using. I bought a new cheap M.2 to test, and the BIOS can't see that either. The computer always POSTs without problems, but now always pushes me into the BIOS, as it can't find any bootable drive.
I've looked over it carefully and can't see anything wrong, or any leaks. BIOS temps look absolutely fine, so I don't think it's a heat issue. I've reset CMOS - no change. I then updated to the most recent BIOS and now it won't even boot from the Windows installation USB. It will post but then hangs when I put the USB in the socket and reboot. It's like every day another drive functions shuts down...
Does this sound like a motherboard going wrong? If so, I can't see any alternative but to take the whole thing apart again! It's obviously a huge pain to repair as I'll have to drain the system.
Thanks for any help.
