Hi,
I am having problems with a new prebuilt system that I have had for the last 3 months.
I don’t seem to be able to get a stable and reliable performance from it. I will try to go into as much detail as I can.
By this I mean I keep ending up having to do fresh installs of Windows 10 and starting over. I just can’t put my finger on what is wrong but you know when you know something just isn’t right.
I don't think I have any viruses or malware; I did post here a few days ago wondering if I might have had one (posted in the Windows 10 forum) and got some replies but the machine has now got more problems before I could try the last couple of things I would advise.
My machine specs are:
i9900K
H115i Pro cooler
Z390 Aorus Master with F8e BIOS (not the final F8 BIOS - only just discovered that the Final has been released)
32GB (2 x 16GB) Dominator Platinum 3200
1 x 1TB 970 Evo NVMe M.2 (bottom slot)
1 x 1TB 970 Evo Plus NVMe M.2 (middle slot under the GPU)
1 x 1TB 850 Evo SATA
1 x 500GB 850 Evo SATA
1 x 240GB 840 Pro SATA
1 x 500GBMX300 SATA
1 x 525GB MX500 SATA
1 x 6TB WD SATA
MSI Gaming X 1080ti GPU (from my previous build)
Seasonic Ultra Prime Titanium 850W PSU.
Windows 10 Pro 64bit v1809
All the drives are reporting as Good in CrystalDiskInfo and my temps seem fine.
I dual boot the machine - one boot for work and one boot for gaming. I hit F12 at startup if I want to switch boot drives.
So far, I've had lots of just what I can only call "odd" behaviour - thiings that i kind of ignored but now as more and more start to happen I wonder...
Main thing is I have had 2 separate incidents of Windows 10 getting stuck in a boot loop of “preparing automatic repair” but it can’t repair anything and I end up doing a fresh reinstall. The first time this happened I was booting from the 970 Evo and the 970 Evo Plus so when I did the reinstall (13th April) I used the 840 Pro and MX500 as a test. Yet less that 2 weeks later (last night, actually) I had the same Automatic Repair looping issue. This time though I did choose the “Reinstall Windows option but Keep My Files” option and this got me back to the desktop, so from this I believe it was my Work drive that had the issues.
I also seem to get a lot of CHKDSK running during the Boot sequence (where I can hit any key to cancel checking) - not every boot by any means but more that I would expect.
It has gotten to the point now where I dread pushing the power button on as I don’t know what to expect next
My next steps intend to be:
Update the Mobo BIOS to the final F8 which I noticed has been out for a month or so.
Only install and boot from one of the NVMe drives - the 970 Evo Plus. I will keep the 970 Evo, 840 Pro, the 500GB 850 Evo and the 6TB WD installed and disconnect the other SATA drives.
And see how things go this time.
My thoughts were did I have too many storage devices attached as the machine is maxed out of drives? I would imagine though that I should be able to use what I had but given I seem to be having CHKDSK running at boot a few times, who knows?
Maybe a fresh BIOS update will help? Does updating the BIOS ever help sometimes?
Could it be a Windows issue each time and not hardware - given how problematic v1809 seems to have been?
Does anyone have any clues, please?
It is starting to really become frustrating and has certainly taken the shine off of the new machine - to the point where I think I’m just not going to bother with it and just use my old 4770K machine instead (which, incidentally, was pretty damn stable).
Sorry for the ramble.
Many thanks for making it this far.
Moley
i9900K
H115i Pro cooler
1 x 500GBMX300 SATA
1 x 6TB WD SATA
Moley
