Weird Keyboard issue
2 Feb 2011
So all of a sudden I'm not able to type a w in uppercase by using shift + w. I can click the w and produce a lowercase letter, but when using shift + w nothing happens. The only way I can get a capital w is to turn on the caps lock. And this is the only key this happens with. I can produce any other letter uppercase with shift.
Anyone know what's causing it?
A Logitech K120. Had it for well over a year. It was pretty cheap, no idea if its still in warranty or not.
Just weird that its only that one key combination that doesn't work. The w key works and the shift key works. They just don't work together.
I don't own another PC...
EDIT: Solved it. Turns out the F10 key was jammed down. When I unstuck it the problem went away.
