weird memtest out come after ramdon bsod
22 Aug 2010
In My Command Center
ok while gaming i had two warnings pop up about a serious hardware failer then a bsod a1 error which i googled and it turns out to be a ram problem!
i re booted my pc and looked into memtest, while i was on the memtest site i noticed my ram maxing out so i re booted again and everything was fine?
i ran memtest on one stick for 7 passes then as the 7th pass finished this happened........
it was still running but does this mean i have a faulty stick of ram?
many thanks
ahhh ive had this exact same issue in the past.
Hopefully, like my case, Nothing to worry about.
Mine was down to a slight power surge.
I then checked my volt/amp/whattage meter that my pc is always plugged into, and it did state a previous small power surge, gave the ram a little too much juice, so it crapped out for a split time.
hopefully yours is nothing to worry about either.
That would make a lot of sense! I will have get my dad To bring his multimeter round and set it up for me
Thanks bud
