Weird MSN prob.
Caporegime
8 Jul 2003
In a house
I done a re-install the other other day, but now MSN will not auto-run and sign in, even though i have it set to do so when it detects an internet connection, ive had to make a shortcut to it on my desktop, and ive got to double-click the **** all the time for it to load and sign in, anyone got any ideas whats up with it
Its never happened before when ive done a re-install, its always loaded and signed in when ive booted up as normal. :confused:
Im running XP with SP3 btw, where as before i was only running on SP1, but i doubt thats got anything to do with it.
Any ideas would be great, thanks. :)
Btw i could try deleting it and re-installing it, but i can't remember the directory that gets left behind which you have to remove yourself, so if anyone can remember that, ill give that a go to. :p
You could download CCleaner and use it to take msn out of the start up programs see if that works i have service pac 3 on my xp machine and have no such problem.
