weird noise from vauxhaull engine?
7 Mar 2005
Evening all!
I was driven into work today by one of my collegues and noticed a weird noise coming from his engine when he switched it off (approx 20 seconds after off).
Opened the bonnet and fired it up again. It seems to be coming from a small grey metal circular bit on the right hand side of the camshaft (between the two cams, looking rearwards). Marked with Siemens on it. Almost sounds like an elctric motor/gears on it's way out(!). Any idea what this bit does? Fairly familiar with engines but not DOHC motors, and not this new either!
The car is a 2003 2.2 Signum.
Sounds a bit modern to me! My old beast is 15 years old and haven't been involved in newer engines.
So what exactly does this do? If it does fail, what sort of cost is it for the part?
