This behaviour baffels me a bit since I have never experienced it with SLi before.
Since 2009 I regularly have run SLi with different clocks speeds and the nVidia drivers have always allowed the cards to run at their individual speeds. I remember nVidia releasing the drivers and pointing out that individual clocks speeds were now supported so NO downclocking !.
However yesterday when I wanted to SLi my Asus GTX 980 Strix with my Gigabyte GTX 980 G1 in SL I noticed something very odd !.
I OC'ed both cards via MSI Afterburner. I OC them individually and not set "sync'ed" in AB settings.
I expected the Gigabyte GTX 980 G1 to boost higher on the GPU core since it's naturally clocked higher than the Asus card - 1228mhz vs 1178mhz.
So I knew the max OC for my Asus card and set it to 1330MHz GPU and 1950MHz Vram.
The Gigabyte card I set to 1350MHz and 1950MHz just to see if the G1 would boost past 1500Mhz.
Now the odd stuff happened ! Regardless of running games or benchmarks the Gigabyte G1's boost clock would always match the boost clock of the Asus card of 1443Mhz !. I tried OC'ing the G1 to 1360MHz core and check again but still it ran 1443Mhz just like the Asus card.
I thought that was weird so I tried OC'ing my Asus card a bit more to 1343Mhz and the Asus boost clock would be 1453MHz. And now the Gigabyte G1 was running 1453MHz too !!. However I noticed my Asus card began to produce green checkerboard patterns some times, so I took it back to the rock solid 1330MHz settings.
So I have NEVER EVER experienced this before ! The Gigabyte G1 automatically limits it's Boost clock to match the Asus Strix.
I have run different manufaturer cards many times and last I had Palit GTX 780 Super Jetstream and Inno3D GTX 780 Ichill HerculeZ X3 Ultra DHS Edition cards running SLi and both ran at their max individual boost clocks !.
Has something changed in the drivers or is it the Maxwell structure ?
Right now I run both cards at 1330MHz GPU and 1950Mhz vram and their Boost clock is rock solid at 1443MHz and never changes (there is no point in OC'ing the Gigabyte any further due to the above symptoms).
However I cannot help feeling that my OC is being held back by the Asus card
, so I'm considering replacing it with another Gigabyte G1.
Maybe your G1 card is not getting the right vcore (like my MSI card) amount and thus is not boosting up enough?
