- 11 Oct 2007
I am facing a weird problem when overclocking my rig. I go inbto the BIOS and change everything i need, reboot my system normally and test it out at the given speed and everything seems to be normal, ORTHOS stable for more than 8 hours, and with the temps not exceeding 60c on 1.3750v.
The problem arises when i have to cold boot, the mobo is stuck at memory testing and reboots itself with the default clocks, it doesnt matter how small/big the overclock is, it will still reboot itself.
When the board is not overclocked this doesnt happen though it does take an unusually high amount of time to pass through the memory testing at POST.
The RAM appears to be stable for hours of testing with memtest without a single error as well...
Here is my rig
Gigabyte p35-DQ6 with F6 BIOS
Intel Quad Pro 6600 G0 Stepping
Crucial Ballistix at 1066 MHz 2.2v
Thermalright Ultra 120 Extreme + 120mm fan
Sapphire Radeon HD2400 Pro fanless
850w OCZ power supply.
I feel really bad about this, everything seems to be stable and then at cold boot its giving me this stupid issue
Here is my rig
