Weird PATH issue
14 May 2009
If I run CMD the usual CMD.EXE window appears but any commands I type end up with something like
Code:
'ping' is not recognized as an internal or external command,
operable program or batch file.
So you say your PATH is broken. Can't disagree. Typing PATH shows the standard output with a list of semi-colon separated directories. First being
Code:
PATH=%SystemRoot%\system32;
And typing
Code:
%systemroot%\system32\ping
runs ping as expected.
If I type PATH to display it, then copy the whole of the PATH=.... and then simply paste it back into the cmd window, redefining the PATH to be the same as before, then the commands are found as expected.
I don't understand how the 2 seemingly identical path values can behave differently.
Any thoughts O clever ones?
TIA
Oh, Windows 11 so I've got the new tabbed cmd app ( Microsoft Windows [Version 10.0.22621.2134] )
Have you done a typo or does it actually return '%SystemRoot%' when checking the PATH?
Because I'm fairly sure it should not say '%SystemRoot%', it should be interpreting that on the fly so when you type PATH you should be getting back 'PATH=C:\Windows\system32;'.
Maybe worth checking out if the environment variable in the registry (HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment) has any weird formatting in the path key, that key should actually be what's using the '%systemroot%' variable. (type should be REG_EXPAND_SZ)
May also be worth checking 'HKEY_CURRENT_USER\Environment' for any untoward user variables, should just be two temp keys and maybe a path for WindowsApps but I'm doing this in Win10 so it maybe slightly different.
Yes it really shows %SystemRoot%, that was a copy and paste from the CMD window. Checking the registry, as suggested, doesn't seem to show me what the problem is.
Just had another play though, used the Control Panel Environment Variable cmdlet, I moved the %SystemRoot%\bin to the end of the list of folders. Ping worked so I went looking for a badly formed folder in the list by moving the entry back up the list until it went wrong. It never did! The %SystemRoot%\bin is the first entry again and ping is again working. All very strange.
Thanks for your help.
Same Windows version and in the new tabbed cmd prompt I get "PATH=C:\Windows\system32"
run sysdm.cpl to open system properties and check your path
I didn't twig this before but the Control Panel did show the full path. I'm guessing when I moved the the folder ordering, using this Control Panel applet, the effect was to replace the %SystemRoot% with the expanded value as PATH how now lost the %SystemRoot% values and got the c:\windows.
Ta for the reply
