Hello!
My PC Speck:
OS: Windows 10 Pro
CPU: i9-11900k(stock 4.8Ghz)
GPU: RTX 3080 MSI Gaming X Trio
RAM: G.SKILL Trident Z RGB 2x16(3600mhz XMP)
Motherboard: MSI Z590 Ace
Storage:
Samsung SSD 980 PRO 1TB(PCIe 4.0)
Samsung SSD 970 EVO Plus 1TB(PCIe 3.0)
PSU: Seasonic PRIME 1000w Platinum
CPU Cooler: Corsair H150i ELITE CAPELLIX 360mm
The problem that I'm having:
For over 4 month I'm facing PC crashes with the error code 141 in reliability monitor.
The crashes most of the time happen when I'm loading a game and screen goes black and the 141 kernel event is produced.
But, as I noticed the described crashed can occur when just booting the PC. Motherboard does all the check successfully, but when booted to windows loading screen, my monitor is just black and there is just a black screen. The issue is fixed with a reboot.
The interesting thing is that I can game for hours some days and no issue, but sometimes I can play a game for 4 hours and launch another game after that and PC crashes with that error. Usually before the crash there is some kind of an artifact in game(like unproperly rendered lights) or just a black screen.
The interesting thing is that the issue went away for some time and started happening again and it's been around like that for over 4 months.
What I've tried:
1. Tested my RAM using Memtest86 Pro 8 passed, no errors where detected, also tried another RAM kit from Corsair also 32 gigs, the issue persisted.
2. Done some stress tests like 3DMark, RealBench, CinebenchR23, AIDA64 stress test, Prime95 and there is no crashes. Which is really strange why it doesn't crash it benchmarks.
3. DDU the Nvidia driver. It does help for some time, but after a while starts happening again.
4. Cheeked all my SSDs in Samsung magician, didn't find any issues.
5. Checked temps, which seems to be ok. GPU ~75c max, with default fan curve. CPU 50-65c.
I'm not sure what causes the issue, but I suspect my graphics card. Since what I've read online points to it.
Would appreciate some suggestions and help with this issue. Thank you!
My PC Speck:
OS: Windows 10 Pro
Storage:
What I've tried:
