Weird PDO issue
Sic
Sic
9 Nov 2004
SO16
I'm sure this is something obvious, but I've been through the documentation and I can't find anything. I'm having a problem with PDO where if I use the same variable twice in a query, it only uses the first one. Example:
PHP:
$this->stm = $this->db->prepare(
  'SELECT * FROM Sample WHERE foo = :col OR bar = :col'
$this->stm->execute(array('col' => 1));
It's completely ignoring the "bar = :col" part and, as such, is returning no results (also no errors, and I can't seem to make it fall over). I can solve this by changing the query to WHERE foo = :col1 and bar = :col2 but I'm not a huge fan of doing that when I shouldn't have to (works fine on my local setup, but not my test setup, which is fedora, if that helps.
Does anyone know of anything that might be causing this?
