Weird price difference
But why are the faster ones £22 cheaper?
The CAS 7 memory will be more expensive to produce and may well run 1866MHz speeds at a lower latency than the other kit as the chips are probably better grade, not always true but very likely. I doubt that 1866 kit can run CAS 7 latencies at 1600MHz at the voltages the other kit can.
