- 4 Nov 2009
- Liverpool
I have been looking at the oc capabilities of an old pc. The bios has facility to increase speed by 10% but doesn't allow you change things manually. It has manual mode but this doesn't work for some reason. Any how I have set it to 10% oc and ran a couple of load tests which were fine. Temps never over 58C. with stock cooling. Reset to factory settings.
Last night I set to 10% oc again and pc rebooted. As windows was loading I got an error message - 'machine had to recover a registry file from log.. operation successful.' Clicked OK and it flashed through a few screens and then went to shutdown screen, 'windows is saving your settings'. Then it hung. Cut off power set bios to no overclock again but the same thing kept happening.
Not seen anything like this on the forum and would appreciate any advice.
The MB is Asus M2 N4-SLI
Athlon dual core 4400+
1Gb RAM
XP Pro.
1Gb RAM
XP Pro.
as I noticed they often have windows partitions
Sound like a screwdriver might be required?
