i format my pc the other day (full format) re-installed windows, everything went fine, installed the graphics card drivers - everything went fine, then when i come to install the motherboard drivers and rebooted the pc it was sticking at the green status bar before loading windwos, tried booting in safe mode and there are no probs, i restored to the last known good configuration and it boots fine so im guessing it must be something to do with the motherboard drivers? although this has happened on the odd ocassion its never failed to work after a few resets, the only thing i have plugged into the usb port is my keyboard and this has never had any issues. ive formated plenty of times with this driver disc and the same setup with no probs?
another thing is when i was resetting the pc to try and get it to boot it was saying there was a boot disk faliure
spec is:
asus a8ne
opteron 148
tagen 580
x800 gto 2
2gb geil
there were no issues before i formated other than windows being messed up
spec is:
asus a8ne
opteron 148
tagen 580
x800 gto 2
2gb geil
