I know this might be appropriate in the HDD section, but then again its quite general....
I've put together my system as detailed in my sig and all is well, except for the fact that I can't connect my DVD-RW because the cable (IDE) isnt long enough. So here's the dilemma, I changed the cable to a longer one that I just bought, but if I use this cable, it doesnt recognise my HDD or CD. I've now tried 2 different longer IDE cables, that both fit, but if I try to use them, it won't recognise my HDD or DVD-RW, and I cant find them if I use the BIOS either.... It's quite a strange problem, anybody know what I can do ?
Thanks in advance,
Kiz
Thanks in advance,
Kiz
